Samsung NP750XDA not charging battery
  • mferna14
    • Jun 2018
    • 1048
    Dear gentlemen., today working on a Samsung Galaxy NP750XDA Laptop (NB3586-NB3587_PCBN_MB_V5), not charging battery. The laptop came with a dead battery & upon testing the battery Ouput coil getting around 6v, assuming that the battery circuit is ok & only the battery has to be replaced. I ordered a new battery, received & installed it but still same, NOT CHARGING. In the start, on the battery + pin I get 17v which is perfect for a 15.4V battery & then the volts drops down to 6v approx & does not charge or work on the battery & the charge LED comes on & then off. I checked each & every MOSFET in this battery circuit, all are good & no shorts at all. The charging chip is BQ25700A, (VCC Pin 1 ,2,3 20v, REGN Pin 6v, VDDA approx 6v, Pin 4 CHRG_OK 3.2V ). All the main volts to the chip seem to be ok. No schematics available for this model. Can anybody help me in this repairs. Thanks in advance
  • mon2
    • Dec 2019
    • 14766
    Hey
    Meter in resistance mode. Measure the full path resistance between pins SRN & SRP (pins 19 & 20) on the charger IC. Compare these values against the reference values in their datasheet or another motherboard schematic. If the values are out of range, the charger IC will sense there is a fault and halt the charging process.
    Expecting this measurement to be ~20R ohms - taken from the EVM schematic from Texas Instruments for this device (
    Post the measurement.
    • mferna14
      • Jun 2018
      • 1048
      Thanks mon2 for the rescue. I will do the measurements tomorrow & inform you. In the meantime, i.e this afternoon, I took out a good BQ25700A from a Lenovo motherboard NM-B741, this board uses the same BQ25700A chip for charging the battery, no chance, still the same. I will check the resistance between pins SRN & SRP (pins 19 & 20), but I sure it will be less than 10ohms as there is a current resistor in parallel. I checked this resistor before & it was fine, but will surely confirm it tomorrow. Thanks
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Julian Bailey
        HP ProBook 445 G8 Battery not charging
        by Julian Bailey
        Hi all
        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
        I have gone around the board with a MM and cant find anything
        Windows shows the battery fine,...
        10-11-2024, 10:34 AM
      • piernov
        Laptop battery charging circuit
        by piernov
        1. Some theory
        1.1. Introduction
        Almost every laptop has a charging circuit of some sort, that does a few things:
        • Manages switching between AC adapter and battery power
        • Manages battery charging and generates power rail to charge battery
        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
        • Narrow VDC (NVDC)
        Texas instrument has a nice overview of these technologies with some more details at https:...
        11-15-2020, 01:31 PM
      • kodox
        ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
        by kodox
        since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
        the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
        what i've done:
        - flashing...
        12-29-2024, 02:49 AM
        Samsung NP750XDA-KDBUK Notebook Specification for Upgrade or Repair
        This specification for the Samsung NP750XDA-KDBUK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP750XDA-KDBUK boardview and NP750XDA-KDBUK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-07-2024, 03:10 AM
