Hello. I'm interested in this topic)) - will the T2 chip from the MacBook Pro 13 fit the MacBook Pro 16 of the same year, the same SSD size? Maybe someone has tried it?
Macbook pro T2 chip change
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by Loki_FidoHi ya folks,
I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
I replaced it and the SSD are fine. No more shorts.
But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
Chip marking... -
by SSBDADC234
When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
Testing the chip pins with a multimeter revealed a short circuit inside the chip.
Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software....04-19-2024, 08:51 PM -
by Aditya11tttAny idea on changing apple mac book nand chips and ram chips on new model 2018 and above and its file and programmer used for configuration of nand chips !!
Channel: Schematics and Boardviews
by BerunHello All,
I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
I read the Chip on board 8 times (with power... - Loading...
