MS-16R31 ver. 1.0 - PU15 identification
This topic has been answered.
  • Iherduleikgemz
    • Jan 2020
    • 22
    • Poland
    Hello
    I have been working on a dead MSI MS-16R4 laptop. It has a blown mosfet on the input side, but also the PU15 is shorting everything to ground. The IC is labeled as AKUK 234. Does anybody know what it exactly is? Im unable to find a schematic for this board :/
  • Answer selected by Iherduleikgemz at Yesterday, 03:49 AM.
    mon2
    • Dec 2019
    • 14666
    MPS # NB685GQ
    https://datasheet4u.com/pdf-down/N/B/6/NB685-MPS.pdf
    • mon2
      • Dec 2019
      • 14666
      MPS # NB685GQ
      • noname2024
        • Aug 2024
        • 294
        • CỎ MỸ XỊN
        Originally posted by Iherduleikgemz
        Hello
        ,IC CONVERTOR,MPS/NB685GQ-Z,QFN-16pin,HIGH CURRENT SYNCHRONOUS BUCK CONVERTER,HALOGEN FREE
        • Iherduleikgemz
          • Jan 2020
          • 22
          • Poland
          Thanks a lot!
          • Shulgin
            Acer predator XB241YU Component identification
            by Shulgin
            I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
            After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
            In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
            I...
            05-11-2024, 11:06 AM
          • thebomb602
            ASUS GA402R IC identification
            by thebomb602
            Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
            also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
            EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
            11-21-2023, 02:30 PM
          • Tend0
            hp elitebook 840 G4 no 5v IC identification
            by Tend0
            Hello everythone
            i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
            i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
            05-31-2025, 09:13 PM
          • Tomylee
            Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
            by Tomylee
            I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
            It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
            I'm looking for help with the following:
            The exact identification or part number of the T5 component
            05-28-2025, 12:42 PM
          • FrozenHaxor
            SOT23 component identification
            by FrozenHaxor
            Hello, I have two identical circuits and one has a component with a hole in it, it is some sort of MOSFET driver, as two gates of large MOSFETs are connected to the lower right pin of it, I'd rather avoid guesswork if positive identification is possible.
            04-09-2025, 03:17 AM
