MacBook Pro 15" Mid 2010
  • jamseh2k
    • Sep 2014
    • AU
    I have motherboard that is doing my head in, it just randomly stopped working and when reading the pins the voltage is going 16.5 to 0 back and forth so I must have a short to ground somewhere.
    The 3.3v rail is fine
    5.5 unknown as does not power on.
    I cant get a solid 12v to power on the mobo, I found a few chips getting warm so removed them both for testing but still going 16.5 0.
    Any ideas?
    anyone got the schem?
  • chipmunk
    • Sep 2014
    • Netherlands
    Re: MacBook Pro 15" Mid 2010
    maybe, but you have to give the motherboard number. Something like 820-xxxx which is etched onto the motherboard, sometimes well hidden and barely visible.
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
      Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
      Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
      10-22-2024, 02:37 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • protocold
      MacBook Pro 15" 2010 820-2850 intermittent charging
      by protocold
      I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
      I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
      when it is not intermittent:
      PPVBAT_G3H_CHGR_R is 12.07v
      when it is intermittent:
      When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
      when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
      data line on the battery...
      07-25-2025, 08:18 PM
