A1990 820-01814-A dead not charging - need help with diagnostics.
  • master_haze86
    • Nov 2023
    • 14
    • Ecuador
    Good day everyone,
    Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
    The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)
    First thing I did was make sure the usb-c ports were clean which were dirty so I cleaned those. Once clean, I then checked if the power was reaching the board by measuring voltage on the PP20V_USBC vbus test pads (XA, XB, TA, TB).
    While the charger is connected to the pad's corresponding usb port, I get 5.1V instead of 20v while showing 0V on the non-corresponding test pads.
    This goes for all of the test pads, except for the XA test pad which shows 2.6V-2.7V while the charger is connected to any of the non-corresponding usb ports and 5.1v when the charger is connected to the corresponding usb port.
    Then I checked F7000 and F7001 both of which have unstable resistance readings, starting out in the 1 to 3 mega ohms range while slowly lowering, then jumping down to 1 kilo ohm and slowly lowering, then jumps to 40 to 60 kilo ohm range and slowly rises, then jumps back up to the 1 to 3 mega ohm range and the cycle sort of repeats from there. Voltage to ground for both F7000 and F7001 with only battery connected is 17.6mV and with the charger also connected, the voltage to ground becomes 12.26V.
    Hope someone here has the patience and time to guide me through diagnosing this board to find the problem. (if the board is the issue to begin with and not the charger, I do not have another original apple usb-c charger to test with, just a lenovo 19.5V usb-c charger which I am hesitant to even test with.)
    Sincerely,
    Rick.
  • mon2
    • Dec 2019
    • 14676
    Remove all power. Disconnect the battery. Meter in resistance mode. Measure the resistance to ground of:
    SMBUS_3V3_BATT_SCL
    SMBUS_3V3_BATT_SDA
    This is to confirm if the TVS ESD dual diode @ U6950 has triggered or not. If yes, this can prevent a boot. Post the measurements.
    • reformatt
      • Feb 2020
      • 1509
      Pull the board out and check each wing for corroded caps, often one will be shorted. You get an accumulation of dust as the Intel machines run quite hot and the fan draws in so much air. Since your PPBUS_G3H isn't shorted, you might be lucky and just have a shorted cap on the 2.5V SSD rail. Depending on the SSD size, you may only have one side populated. The most common fault is failure of one of the SSD 2.5V TPS buck converters, but that usually results in a simultaneous short on PPBUS_G3H and the SSD 2.5V rail.
      • master_haze86
        • Nov 2023
        • 14
        • Ecuador
        SMBUS_3V3_BATT_SCL
        SMBUS_3V3_BATT_SDA
        Measuring resistance to ground using the SMBUS_3V3_BATT_SCL and SMBUS_3V3_BATT_SDA test pads I get an unstable reading that will not settle. It acts a bit weird, the first moment I touch the probes to the testpad I get a reading of about 10 kilo ohm and rising fast, when I then touch the other pad I get a reading of 1.3 mega ohm and dropping slowly, when i then touch the first pad again I get the same mega ohm reading that slowly lowers. If I then wait a bit and measure again, the same thing happens again, first about 10 kilo ohm and rising fast until one switches pads at which point the resistance shows as 1.3 mega ohm and slowly lowering.
        After taking readings of SMBUS_3V3_BATT_SCL and SMBUS_3V3_BATT_SDA I took a closer look at the wings and I think I might have found the issue. Around Q3100 there is some slight corrosion present both on the left row of caps and the row of caps and resistors to the right of Q3100. Also looks like CC772 and R2836 have corroded to the point they fell off the board, they are missing and the pads look corroded. Since I cannot afford a microscope with the small number of clients I have, I guess I am going to have to find a colleague to help out. >_<
        • mon2
          • Dec 2019
          • 14676
          Try to use your phone to zoom in on the same region for inspection. Some of the phone cameras are amazing for this line of work. Last year in China, found at least one vendor with a slip on lens that allows the phone to be used as a microscope. Was under $10 USD if I recall correctly.
          • master_haze86
            • Nov 2023
            • 14
            • Ecuador
            Haven't been wanting to, because I know they really aren't that good, but guess I will have to fork over the 25 dollars for one of those usb "microscopes" just to do this repair.
            I've been searching locally for a replacement for CC772 which according to schematics is 0201 12pF 25v. Though i closest i can find is 15pF 50v. Would that work or does it have to be 12pF specifically?
            The resistor R2836 upon closer inspection seems to never been installed.
            Sincerely,
            Rick.
            • mon2
              • Dec 2019
              • 14676
              Do not purchase a low end microscope. Shop around for something better. Consider a 4k unit with the proper optics. Check Aliexpress and review samples of their output. Lots of good videos on what to watch for but start with a simple - all edges of the view area must be sharp and in focus. Can you solder under the microscope?
              • master_haze86
                • Nov 2023
                • 14
                • Ecuador
                Would it be an issue to change CC772 with a 15pF 50v 5% capacitor instead of the original 12pF 25v 5%?
                I would absolutely purchase a 4k model with proper c-mount optics if I could afford one, really! We've got a distributor for mechanic brand equipment here in Ecuador that has nice trinocular microscopes but they cost $300-$600 each. Just mentioning that minimum wage here is $450 and most of the time I struggle to earn even half of that each month, that should give you an insight in how high of an investment it would be for me. At best I am going to be able to afford one of these $100 1080p ones that I can hook up to my pc:
                • mon2
                  • Dec 2019
                  • 14676
                  No. This part is not critical nor will it be missed if you did not replace it. Ok to use the 15pf.
                  • mon2
                    • Dec 2019
                    • 14676
                    Understood. We should barter for some of your hot women. SMDFlea is hording all the good ones.
                    Pretty sure that Mechanic will be at the electronic trade fair next month in HK. I recall seeing their CEO last time. Their staff noted that he is loaded. I think the new trend is to have a 4k microscope camera module AND thermal sensor in one unit. Not sure if we like that because to us, it is a royal pain to take thermal shots of larger boards like iMACs while they remain inside of their enclosures. Better, IMHO to have a thermal camera that is mounted to a phone. Will share what we see at the mobile fair.
                    • master_haze86
                      • Nov 2023
                      • 14
                      • Ecuador
                      So I had a lot of luck and a friend of mine for whom I have done a lot of pro-bono work reached out to me and asked if I needed any tools for my work as he had received a nice windfall and could help me out as compensation for all the work I had done without charging a penny. So I pointed out my lack of a microscope. I am pleased to say I no longer lack a microscope! I now have a mechanic robot z4. ^_^
                      Ok, enough with celebrating the new tool, back to work. I used the microscope to check the area around Q3100 where the corrosion was and the capacitor that got ripped off the pad. Did not see any other issues in that area, just cleaned up the remains of the pads of CC772 and left without replacing. Upon inspecting the rest of the board with the microscope I noticed that C5110 had busted its guts and had copper sticking out the top, so replaced that with a 100nF/0.1uF 10v one. For the rest I did not spot any other corrosion nor damaged components. So I put everything back together and it is still not turning on.
                      Checking the test pads around the usb ports, I noticed that the test pad of PP20V_USBC_TB_VBUS reads just 5.1V instead of 20V. So 20V rail is still missing, I can find 1.8V 3.3V 5V 12V. This is my last chance to fix this board, if I can't fix it, I will have to tell my client to go somewhere else or to just replace the motherboard in its entirety which I hope not to have to do.
                      • master_haze86
                        • Nov 2023
                        • 14
                        • Ecuador
                        mon2 Any ideas as to what to check next?
                        • mon2
                          • Dec 2019
                          • 14676
                          Currently in Asia and without access to my office tools and proper beauty sleep.
                          What is the current draw?
                          T2 firmware may be corrupted. Do you have PP3v3_S5 rail?
                          • master_haze86
                            • Nov 2023
                            • 14
                            • Ecuador
                            Unfortunately my usb volt meter died on me the other day, but checking the bottom of the board (the side facing you when laptop is flipped over with the cover removed) for PP3v3_S5 I do not get a 3.3v reading, just a few milivolts.
                            Hope you are doing well and have fun in Asia while there. Business trip to an expo I am guessing?
                            Thanks for all the help so far.
                            Sincerely,
                            Rick.
                            • motormayhem
                              Lenovo T460 Only Charges on One Charger
                              by motormayhem
                              Laptop Question
                              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                              05-12-2023, 01:46 PM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
                            • flat-earther
                              how to prevent a connected charger from draining battery when not charging?
                              by flat-earther
                              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                              So the battery is backfeeding the charger and being drained.
                              How can I prevent...
                              08-07-2025, 01:04 PM
                            • flat-earther
                              ASUS X54H laptop thinks it's always charging even with charger unplugged
                              by flat-earther
                              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                              Windows also shows ''Plugged in'' when charger is not connected.
                              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                              If I let battery run out and say it has 3% Windows will...
                              06-24-2025, 09:32 AM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
