When to replace KBC?
  • MDY
    • Jan 2014
    • 75
    • Spain
    Normally when you replace KBC? Which case?
    If I have 3V and 5V and laptop doesnot run and doesnot try to run, should be bios or KBC, right?
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: When to replace KBC?
    not only , if KBC detects something abnormal in some hardware part its suficient to not start . usually you must make some measures on bios and KBC to know if all feeds and signal are present to make the board work . in any case here is a simple turorial
    0. When BIOS & EC-firmware 100% are working
    1. When EC power is present, his quartz working and EC reading the bios data (look data exchange on BIOS chip an oscilloscope)
    2. When ACIN = 3.3V
    3. When LID_SW# = 3.3V
    4. When EC drop RESET from SouthBridge, т.е. EC_RSMRST# = 3.3V
    5. When by pressing of the power button the signal ON/OFFBTN# falls to zero and the same signal is broadcast in PBTN_OUT#
    6. When from the SouthBridge signals PM_SLP_S3# and SLP_S5# are drop, i.e. voltage on them will be 3.3V
    Under these conditions EC should give command for start.
    i hope it helps but there are as well more usefull things to chek , this is a simple chekout
    • MDY
      • Jan 2014
      • 75
      • Spain
      Do you make measure on bios? In Bios only I measure 3V. Can I measure something more?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        u can measure the bios loading with osciloscope
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          pin 1 spi , but for that like KTM only with microscope , with VM you can notice very
          small oscillation on votlage , but that cannot confirm you much .
          • MDY
            • Jan 2014
            • 75
            • Spain
            Measure the bios loading with osciloscope is good idea? Should I get a osciloscope only for this?
            What do you mean with KTM?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              digital osciloscope ffor usb cost about 100e.
              if u r not technician it is useless for u
              • MDY
                • Jan 2014
                • 75
                • Spain
                can you give me sime link to see on ebay or internet?
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
