ASUS E410MA no 5v/3v on board.
  • someonenotyou
    • Feb 2021
    • 59
    • LV
    Hi.
    I have a ASUS laptop with board number E410MA, which does not power up.
    By the looks of things, it does not generate 5v, 3v, 1.8v and 1.2v.
    The main power rail is there - 19.5V is present and goes to every IC.
    By measuring various components, I found these readings:
    EC_RST# - 2,7V
    RTEST# - 2,8V
    RTC_RST# - 2,8V
    +VCCRTC_3P3 - 2,85V
    +RTCBAT - 3V
    P_CHG_VDD_20 - 5V
    P_CHG_ACOK_10 - 5V
    From the battery I get 3V at RTCBAT, but 0V on main connectors when connected to the board.
    I have a boardview of the board, but I could not find the schematic, so I am at the loss.
    Where should I start to look?
    Thank you.
    Boardview file - https://www.badcaps.net/filedata/fetch?id=2128752
  • mon2
    • Dec 2019
    • 14544
    Which connector is 0v on the board ?
    • someonenotyou
      • Feb 2021
      • 59
      • LV
      BAT_CON does not give any voltage to the board.
      • mon2
        • Dec 2019
        • 14544
        Share the topside markings of PU8901 = battery charger IC.
        • someonenotyou
          • Feb 2021
          • 59
          • LV
          The markings are:
          intersil
          9238CH
          W213E3
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • DynaxSC
            ASUS STRIX Z490-F GAMING - No POST, stubborn board
            by DynaxSC
            I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
            The situation looks like this:
            After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
            1. RTC oscillates normally (32.768KHz).
            07-08-2022, 05:45 AM
          • rayshine03121408
            I Need Working BIOS for ASUS E410MA R7.1
            by rayshine03121408
            Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
            Model: ASUS E410MA-TB.CL464BK
            SN: N8N0CX06E199324
            BoardModel: E410MA R7.1
            08-26-2025, 05:36 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
