A2992 - 5V - 0.00A - No Power
  • applejuice95
    • May 2023
    • 41
    820-02918 - 2023 M3 A2992
    - 5V 0.00A on Meter - USB-C
    - No light on MagSafe
    Small corrosion on UR730, and CR765 - Cleaned and scrubbed with ISP
    Re-assembled. Tested, and computer worked, battery charged. Today after replacing a new USB-C I/o board, the machine no longer works.. We realized this was the wrong part, it was a port for A2442/A2485. The M3 uses a new part 821-04548-A.
    After this, now computer has no power.
    -PPBUs_AON = 0.00V
    -PP3v8 = 0.00V
    - PPDCIN_AON (F5600) - 5V
    No DFU mode.
  • mon2
    • Dec 2019
    • 14334
    Remove all power. Meter in resistance mode. Measure the resistance to ground of PPBUS_AON. What is the exact resistance?
    • applejuice95
      • May 2023
      • 41
      Measuring at C5253 & C5254 - 135ohms same thing near C9803
      • mon2
        • Dec 2019
        • 14334
        Connect the power adapter. Carefully measure the voltage to ground of:
        PPCHGR_VDDA
        PPCHGR_VDDP
        SMBUS_BATT_SCL
        SMBUS_BATT_SDA
        • applejuice95
          • May 2023
          • 41
          PPCHGR_VDDA - 4.46 V
          PPCHGR_VDDP - 4.416 V
          SMBUS_BATT_SCL - 0.0V
          SMBUS_BATT_SDA - 0.0V
          (board is out of machine, on bench)
          • mon2
            • Dec 2019
            • 14334
            Remove all power. Measure the resistance to ground of PP1V8_S2. What is the resistance?
            PP1V8_S2 is the LDO output created by the UF400 PD controller.
            • applejuice95
              • May 2023
              • 41
              1.4Kohm
              • mon2
                • Dec 2019
                • 14334
                No short here.
                With no power to the board what is the resistance to ground of PP3V8_AON?
                Not sure on which PD controller is active for the port under use.
                Test if you have a voltage output at:
                PP3V3_UPC1_LDO (UF500)
                PP1V8_UPC1_LDO (UF500)
                PP1V5_UPC1_LDO_CORE (UF500)
                PP3V3_UPC0_LDO (UF400)
                PP1V8_UPC0_LDO (UF400)
                PP1V5_UPC0_LDO_CORE (UF400)
                For the active USB-C port, the local PD controller linked to that USB-C connector will offer the above LDO rails otherwise something is wrong.
                Based on the earlier posts, you are missing the 1v8 rail required for the I2C communication with the buck / boost regulator for PPBUS_AON.
                • applejuice95
                  • May 2023
                  • 41
                  Thanks Mon, checking on Monday. we are closing out for the weekend. Thank you for all of your help, talk later.
                  • applejuice95
                    • May 2023
                    • 41
                    PP3V8_AON - Resistance to Ground = 400ohms (starts around 100, builds up, stabilizes at 400).
                    (With Power cable in USB-C port #2) These are the voltages for UF500
                    PP3V3_UPC1_LDO (UF500) - 3.23V
                    PP1V8_UPC1_LDO (UF500) - 0.00V
                    PP1V5_UPC1_LDO_CORE (UF500) - 1.5V
                    Yes it would seem 1.8V rail is absent. 1.8V rail is also absent when power is moved to USB-C port #1 (just right of the MagSafe) - 3.3V is present on UF400, but 1.8V is not.
                    Checking for resistance to ground with power removed,
                    PP1v8_AON on C2221 - 23kOhms
                    PP1V8_S2 - 14kOhms
                    PP1V8_AWAKE - 4kOhms
                    • mon2
                      • Dec 2019
                      • 14334
                      Test for the PP1V5_UPCx_LDO_CORE rails on each PD controllers which feeds the BMC interface used by the CCx lines to select the 20v.
                      • applejuice95
                        • May 2023
                        • 41
                        - The 3 USB-C PDs
                        PP1V5_UPC0_LDO_CORE
                        - 1.5V
                        PP1V5_UPC1_LDO_CORE​ - 1.5V
                        PP1V5_UPC2_LDO_CORE - 1.5V
                        - The MagSafe
                        PP1V5_UPC5_LDO_CORE - 1.5V
