A2992 - 5V - 0.00A - No Power
  • applejuice95
    • May 2023
    • 49
    820-02918 - 2023 M3 A2992
    - 5V 0.00A on Meter - USB-C
    - No light on MagSafe
    Small corrosion on UR730, and CR765 - Cleaned and scrubbed with ISP
    Re-assembled. Tested, and computer worked, battery charged. Today after replacing a new USB-C I/o board, the machine no longer works.. We realized this was the wrong part, it was a port for A2442/A2485. The M3 uses a new part 821-04548-A.
    After this, now computer has no power.
    -PPBUs_AON = 0.00V
    -PP3v8 = 0.00V
    - PPDCIN_AON (F5600) - 5V
    No DFU mode.
  • mon2
    • 14657
    Remove all power. Meter in resistance mode. Measure the resistance to ground of PPBUS_AON. What is the exact resistance?
    • applejuice95
      • May 2023
      • 49
      Measuring at C5253 & C5254 - 135ohms same thing near C9803
      • mon2
        • 14657
        Connect the power adapter. Carefully measure the voltage to ground of:
        PPCHGR_VDDA
        PPCHGR_VDDP
        SMBUS_BATT_SCL
        SMBUS_BATT_SDA
        • applejuice95
          • May 2023
          • 49
          PPCHGR_VDDA - 4.46 V
          PPCHGR_VDDP - 4.416 V
          SMBUS_BATT_SCL - 0.0V
          SMBUS_BATT_SDA - 0.0V
          (board is out of machine, on bench)
          • mon2
            • 14657
            Remove all power. Measure the resistance to ground of PP1V8_S2. What is the resistance?
            PP1V8_S2 is the LDO output created by the UF400 PD controller.
            • applejuice95
              • May 2023
              • 49
              1.4Kohm
              • mon2
                • 14657
                No short here.
                With no power to the board what is the resistance to ground of PP3V8_AON?
                Not sure on which PD controller is active for the port under use.
                Test if you have a voltage output at:
                PP3V3_UPC1_LDO (UF500)
                PP1V8_UPC1_LDO (UF500)
                PP1V5_UPC1_LDO_CORE (UF500)
                PP3V3_UPC0_LDO (UF400)
                PP1V8_UPC0_LDO (UF400)
                PP1V5_UPC0_LDO_CORE (UF400)
                For the active USB-C port, the local PD controller linked to that USB-C connector will offer the above LDO rails otherwise something is wrong.
                Based on the earlier posts, you are missing the 1v8 rail required for the I2C communication with the buck / boost regulator for PPBUS_AON.
                • applejuice95
                  • May 2023
                  • 49
                  Thanks Mon, checking on Monday. we are closing out for the weekend. Thank you for all of your help, talk later.
                  • applejuice95
                    • May 2023
                    • 49
                    PP3V8_AON - Resistance to Ground = 400ohms (starts around 100, builds up, stabilizes at 400).
                    (With Power cable in USB-C port #2) These are the voltages for UF500
                    PP3V3_UPC1_LDO (UF500) - 3.23V
                    PP1V8_UPC1_LDO (UF500) - 0.00V
                    PP1V5_UPC1_LDO_CORE (UF500) - 1.5V
                    Yes it would seem 1.8V rail is absent. 1.8V rail is also absent when power is moved to USB-C port #1 (just right of the MagSafe) - 3.3V is present on UF400, but 1.8V is not.
                    Checking for resistance to ground with power removed,
                    PP1v8_AON on C2221 - 23kOhms
                    PP1V8_S2 - 14kOhms
                    PP1V8_AWAKE - 4kOhms
                    • mon2
                      • 14657
                      Test for the PP1V5_UPCx_LDO_CORE rails on each PD controllers which feeds the BMC interface used by the CCx lines to select the 20v.
                      • applejuice95
                        • May 2023
                        • 49
                        - The 3 USB-C PDs
                        PP1V5_UPC0_LDO_CORE
                        - 1.5V
                        PP1V5_UPC1_LDO_CORE​ - 1.5V
                        PP1V5_UPC2_LDO_CORE - 1.5V
                        - The MagSafe
                        PP1V5_UPC5_LDO_CORE - 1.5V
                        • applejuice95
                          • May 2023
                          • 49
                          Have any more ideas?
                          I can't help but feel like this was caused by installing the wrong USB-C i/o board.
                          Mobile Sentrix sells them, but they're selling A2442/A2485 i/o boards as being compatible with A2992/A2991 M3 models which it is not.. Different part number entirely.
                          Originally client had a no response machine. We inspected the usb-c port that works with PP1V5_UPC2_LDO_CORE .. It was all burned up. Removed it, and reinstalled board with this one i/o board removed from the equation. There was a tiny amount of corrosion near U730 we cleaned, but the machine booted fine. It worked, charged the battery to 100%.. The next day after ordering what we thought was the correct replacement for the burned up i/o ubs-c.. On the first try, only metered at 5V 0.00Amps.. Has been this way ever since. Hard to not draw this conclusions that it was the improper equipment which caused this problem.
                          I only can hope it is not U8100
                          • mon2
                            • 14657
                            Suggest to order the relatively new Qianli iBridge A3 Tester to allow you to quickly confirm the state of the USB-C ports. Also acts like a USB-C meter, etc.
                            https://www.mobilesentrix.com/ibridg...-tester-qianli
                            Not sure about the compatibility across the USB-C paddle boards at this time. What are the markings (silk screen) on the A2992 paddle board? I do have a good contact at Mobile Sentrix (Canada) and can alert him if there are errors on their website. It is important to have the proper connector onboard.
                            • applejuice95
                              • May 2023
                              • 49
                              Heres the item: https://www.mobilesentrix.com/usb-c-...2485-late-2021
                              Says compatible with M3 14" & 16"
                              I do not believe this to be true. The part number for the M1 Pros is indeed 820-03084-02/ 923-10062 and this is indeed what they're selling.
                              For A2991/A2992 M3 models. the part number is 821-04548-A (or 821-04548-01)
                              Similar to how the A1707 ports were different from A1990 even thought the connector was the same.
                              I believe installing this part, and plugging up power may have shorted this 1.8V rail. Which I'm still puzzled on.
                              I read through the only other similar article on here, where you had helped a gentleman with an M2 A2338 with a similar short. 5V 0Amps, missing 1.8 rail.. Kind of left it in the wind but looked like U8100 was shorted. Which I REALLY hope isn't the case here.
                              They said they've forwarded to Moosa for review. I also sent them some photos of the 24" iMac displays they're selling as compatible for M3 an M1 models which is also not true. The daughter board and camera/ALS sensors were totally different sizes even thought the LCD is the same. Doesnt work lol
                              • mon2
                                • 14657
                                Very interesting review. Also have alerted the team in Canada on this thread.
                                At this time, do you have the proper USB-C paddle board for your unit? Any luck with a DFU with the proper paddle board?
                                • applejuice95
                                  • May 2023
                                  • 49
                                  Waiting for one coming off of eBay then going to re-run it.
                                  You think its possible with that rail being absent that DFU revive can still be a possibility?
                                  • mon2
                                    • 14657
                                    We have an imac in from repair (for a while now) that is in a similar position. From other cases that are public, most likely to be tossed into the landfill but we are stubborn and have countless hours into the attempted repair. With feedback from Master Liu, he suggested that the T2 firmware is corrupt. We too do not have the 1v8 rail on this imac which is created by a local PMU. He noted that a corrupt T2 firmware can cause this issue. To us, it is a catch-22, from what we know, you need the 1v8 to perform the DFU but curious to know of your position. He also mentioned that it is ok to take the T2 firmware off another board to place onto ours and then continue to test with the Apple configurator to restore the unit. The parts are extremely small and the board is very crowded. Will try these ideas this week.
                                    Find it strange that BOTH pd controllers are missing their 1v8 rail. For this reason, the Qianli iBridge A3 tester may offer some help on your case. Test if the 1v8 is present on other units you may have with this PD controller. As far as I can see, this 1v8 rail should should enable upon power up since it is only a low current LDO. Assuming the LDO is burnt out, then the pd controllers would have to be replaced but the resistance to ground show they are not shorted.
                                    • applejuice95
                                      • May 2023
                                      • 49
                                      What if, we set up the unit for a DFU revive and while running through the process -- we inject 1.8V into the 1.8 rail.. Just give her what shes missing.
                                      If its incapable of sending 1.8V through the rail potentially due to a firmware corruption, but the only way to fix the corruption is a DFU. Supplement the voltage with an artificial V-IN? Anyone ever done this?
                                      This is one of those, "sounds good on paper" ideas but, hey who knows.
                                      • mon2
                                        • 14657
                                        lmao - felt like doing the same here with the imac with 100+ cores but a hidden voice told me to not do this. Try the front door for the DFU and see if that fixes anything. Being a non-Intel box does not help matters here either.
                                        • rilley
                                          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                          by rilley
                                          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                          And the resistor L4004 is literally burned.
                                          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                          07-10-2024, 01:57 AM
                                        • drscoot
                                          usbc connector replacement on mobile
                                          by drscoot
                                          I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
                                          The battery is still charging (red led), but no power on.
                                          I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
                                          07-13-2025, 02:37 PM
                                        • nikolayu
                                          Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
                                          by nikolayu
                                          I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
                                          When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
                                          Other usbc is charging fine,
                                          I installed lates bios and firmwares for thunderbolt and battery.
                                          Could be faulty JHL8040R controller?
                                          08-31-2024, 11:08 AM
                                        • defdjamel
                                          internal short cut - 820-02935 -A2992 - macbook pro 16" m3 max
                                          by defdjamel
                                          820-02935 - a2992 - macbook pro 16" m3 max
                                          Laptop: 5V - 0A
                                          Issue: PPBUS_AON_SPKRAMP_ABC and PPBUS_AON shorted.
                                          • On PPBUS_AON_SPKRAMP_ABC, capacitor CR635 was damaged (melted) and created an internal short circuit to ground.
                                          • I removed faulty components (CR635, CR634, CR633) and also chip UR630.
                                          • Result:
                                            • PPBUS_AON_SPKRAMP_ABC → still shorted
                                            • PPBUS_AON → still shorted
                                          When I inject 3 V / 1 A on PPBUS_AON_SPKRAMP_ABC, heating occurs on pad CR635.
                                          I suspect that during the failure, the pad and line PPBUS_AON_SPKRAMP_ABC melted into ground( i try to...
                                          09-20-2025, 06:16 AM
                                        • defdjamel
                                          macbook M3 A2992 820-02918 - No backlight
                                          by defdjamel
                                          no backlight on macbook 14" M3 A2992 820-02918,
                                          PPVOUT_LUXE : 12V
                                          BL_PMIC_PWR_EN = 1,2v
                                          the value is normal for 1.2v ?
                                          voltage direct on jumper
                                          is someone already repair this model?
                                          thanks
                                          09-03-2025, 08:28 AM
