HP ProBook 430 G4, 440 G4 - MPM unlock
  • Rainbow
    • Aug 2005
    • 1372
    Got a dead ProBook 430 G4. Unfortunately the CPU was dead (shorted) so I replaced the board. To edit DMI data, MPM has to be unlocked. But the "new" board was used and thus locked.
    None of the methods found online worked. This method works:
    1. Dump the BIOSes from both boards.
    2. Extract NVRAM (Intel image -> BIOS region -> EfiSystemNvDataFvGuid) from the original board BIOS (e.g. using UEFITool).
    3. Replace NVRAM in the new board BIOS with file from (2).
    4. Use hex editor to edit HpMpm NVRAM variable - set the bytes to 01 22 00 00 00 00 00 00 (01 = enabled, 0x22 = remaining boot count until autolock).
    5. Boot the new board with this modified BIOS. MPM is now unlocked and all DMI data preserved. Change board serial number using wndmifit. Reset BIOS settings to factory default and also reset security.
    6. Update the BIOS and ME firmware.
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Dihpez
    Need Bios unlock for HP Probook 450 G7
    by Dihpez
    Greeting,
    I would like the bios unlocked and absolute presistance disabled/removed.
    Thanks upfront for your time....
    07-29-2025, 07:53 PM
