MacBook Pro M1 A2338 820-02020 - No WiFI/Bluetooth or internal display
  • mcbadcbv
    • Jul 2025
    • 6
    I have a MacBook Pro M1 A2338 820-02020. It boots to OS but WiFi/Bluetooth are non-functional (exclamation point through WiFi symbol in menu bar) and the display is not working.
    Starting at the WiFi chip... PP3V3_S2_WLBT_ISNS is fluctuating at around 2.4V. No shorts detected around UL000.
    PPBUS_AON is 12V steady, but PPBUS_AON_3V3_S2_VIN_ISNS (measured at CC721) is 2.76V.
    LC710 is getting 2.4V at P3V3_SW, which explains PP3V3_S2 fluctuating around 2.4V.
    No detected shorts around UC710.
    This makes me believe that RD560 has failed and is not supplying CC721/UC710 with 3.3V. This is a common issue according to other threads I've read.
    Does this sound plausible? My next question is, what type of component is RD560, and is it possible to order one? I do not have any donor boards at the moment.
    First post and I'm a beginner repairing a personal machine. Appreciate any insight!
  • mon2
    • 14692
    RD560 is a current sense resistor. Rare for this part to fail. Remove all power. Measure the resistance across this part. Touch your meter probes together. Compare the 2 values from these measurements. Each should be identical since most meters cannot measure such a low resistance like that at RD560​.
    If you see a much higher value here then yes, RD560​ is a suspect. Replacements should be available from Digikey / Mouser.
    What is the exact resistance to ground of LC710 ​? The fault may be in the feedback resistors on the same switching regulator. The resistors are used to define the output voltage.
    • mcbadcbv
      • Jul 2025
      • 6
      Thank you for explaining that. Here were the threads I was referencing that pointed me to RD560:
      RD560 must have same voltage on all 4 pins.
      However, important is to get 12.5V at UC710.
      That means RD560 is good.
      I do not believe UC710 is getting 12V on my board because PPBUS_AON_3V3S2_VIN_ISNS is only getting 2.76V (measured at CC721).
      What is the exact resistance to ground of LC710 ?
      Not sure if I'm able to get a good reading - seeing 65K Ohms. It climbs (charging?) but slows to 65.
      Thanks for your help.
      • mcbadcbv
        • Jul 2025
        • 6
        Sorry, just realized a mistake in my original post - I meant to say 12V not 3.3V. It should read:
        "This makes me believe that RD560 has failed and is not supplying CC721/UC710 with 12V. This is a common issue according to other threads I've read."
        CC721/UC710 is only receiving 2.76V on my board at the moment.
        • mon2
          • 14692
          Remove all power. Measure the resistance to ground of CC721/UC710.
          What is the exact measurement in ohms?
          • mcbadcbv
            • Jul 2025
            • 6
            Resistance is to ground is very high at ~10 Mohms.
            • reformatt
              • Feb 2020
              • 1528
              Interesting! At face value, it does look like RD560 is open or high resistance (or corroded underneath). It's a 50 milliohm 1/3W current sense resistor, can't say I've ever seen a CSR actually fail, but then that's just me.
              There are plenty of these resistors on older boards (search for 107S00017 in FlexBV shows many models have it). So if you have some old T1 or T2 boards you should be able to locate a donor. Failing that, closest I found was one from LittleFuse (P/N: L4CC0306QLR050FNR). Available from Mouser or Digikey.
              • Orux
                Macbook Pro M1 A2338 13"
                by Orux
                I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
                I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
                One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
                09-22-2025, 12:54 PM
              • sdogs
                macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                by sdogs
                Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                06-27-2025, 01:58 PM
              • sdogs
                by sdogs
                06-27-2025, 11:26 AM
              • mkdj
                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                by mkdj
                About me, my goal and the equipment I (don't) have:
                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                About my issue and my goal:
                A friend of mine has a MacBook Air M1 A2337 that does not...
                04-03-2025, 08:28 AM
              • classicandy
                MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                by classicandy
                Hi Everyone,
                Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                04-14-2024, 12:00 PM
