Voltage +DC_IN of an alienware at 16 volts
  • Bradbeat
    • Jul 2025
    • 9
    • Belgium
    Hi everybody,
    I would like to know if the 16v +SDC_IN is normal given that the 19 v comes until the PQS07 and PQS09 mosfets?
    If yes i'can't figure it out why and if it's not neither😁
    The upper part with PQS27 and PQS24 is not populated on my board
    You can find the schematic on page 84
    Could you help me with that?
    Thank you already.
  • Loretto
    Samsung SMPS BN44-00339A
    by Loretto
    this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
    I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
    I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
    I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
    03-29-2025, 08:30 AM
  • Loretto
    by Loretto
    03-28-2025, 10:28 AM
  • rddube
    Lenovo L490 Ram voltage circuit malfunction
    by rddube
    Hello friends,
    Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
    I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
    07-15-2025, 04:41 PM
  • Fernon@Repair
    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
    by Fernon@Repair
    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
    VCCIO voltage ok
    VCCSA Voltage OK
    VCCPLL Voltage OK
    Ram Voltage ok
    RamVTT OK
    VPP 2.5 OK
    But No Core Voltage
    and i want to this vrm ic datasheet or pinout (ISL69269)
    anyone have this ic pinout voltages?...
    06-25-2025, 07:19 AM
