acer a515-52g-4830 5valw 3valw missing
  • Kshi
    • Aug 2024
    • 20
    • Philippines
    hello,
    this is my third time trying to revive dead laptops.
    I got this acer does not have power light
    First I test
    dc 19v-ok but +5valw and +3valw is missing
    i remove the board to test more but i didnt find anything
    no shorts no corrosion
    but i get +3vlp and +5vlp present
    and now i dont know what to do anymore
    hope someone can help me and improve my skill
    Link to schematic - https://www.badcaps.net/forum/troubl...hematic-needed
    Last edited by SMDFlea; 07-25-2025, 03:21 AM. Reason: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/schematic-requests-only/83799-acer-a515-52-la-g521p-schematic-n
  • mon2
    • Dec 2019
    • 14694
    The LP and ALW rails are linked to the same controllers. There should be a 3v3 regulator and another for the 5v rail.
    Remove all power. Measure the resistance to ground of each of the missing rails = ALW rails. If there is a lower than normal resistance, there is a fault on that rail. If the resistance is ok, check if the EN = enable signals are present for the respective ALW rails.
    • Kshi
      • Aug 2024
      • 20
      • Philippines
      So I test the 1st mosfet source and drain and i found that is short so i remove it and found a jumper wire below the chip.
      I replaced the 1st mosfet but now i get
      Drain 19v
      source 0v
      gate 0v
      maybe the charging ic is busted because of jumper on first mosfet?
      • mon2
        • Dec 2019
        • 14694
        The tech before you placed a wire to bypass the mosfet? Hack. If this could be justified, the vendor would certainly consider the same reduction in the bill of materials to increase their profits. Rarely would I agree to bypass such parts.
        Remove all power. Measure the resistance across the 2nd DCin mosfet @ PQ311:
        source (1-2-3)
        gate (4)
        drain (5-6-7-8)
        Post each measurement. Each measurement should be high hundreds of k ohms or higher else the mosfet is a suspect.
        • Kshi
          • Aug 2024
          • 20
          • Philippines
          This is the measurement i got at PQ311
          Source- ol
          Gate- ol
          Drain- 4.5kohms
          1st mosfet is
          Source- ol
          Gate- ol
          drain- 330kohms
          • Kshi
            • Aug 2024
            • 20
            • Philippines
            I remove the 2nd mosfet and it seems to be working fine, this what im getting now without it
            PQ311
            Source ol
            Gate ol
            Drain 4.5k
            I think one of this mosfets is the problem?
            PQ312
            Source 520k
            Gate ol
            Drain 4.5k
            PQ305
            Source 520k
            Gate 520k
            Drain 4.5k
            or the charging ic is broken?
            • mon2
              • Dec 2019
              • 14694
              Sorry. Measure the resistance as:
              source & drain
              source & gate
              gate & drain
              post each measurement. No power to the board during these checks.
              • Kshi
                • Aug 2024
                • 20
                • Philippines
                Pq 310
                source & drain 400
                source & gate 500
                gate & drain ol
                PQ311
                source & drain 450ohms
                source & gate 500ohms
                gate & drain ol
                • mon2
                  • Dec 2019
                  • 14694
                  These are very low measurements for a good mosfet. Start with removing PQ311 off the board. Flux and remove. Then allow it to cool down and then test the removed mosfet again using the same method. Are the measurements still this low? A good mosfet should be hundreds of k ohms or higher.
                  If the readings remain low, replace the mosfet. Proceed to test PQ310 again with PQ311 removed. Repeat to replace if the measurements remain low.
                  Based on the measurements, it appears that both mosfets are defective.
                  Be sure to measure the resistance to ground of PQ311 (drain pins = 5-6-7-8) = +19V_P2. If this main power rail is low then there is a shorted part onboard and causing the DCin mosfets to die.
                  • Kshi
                    • Aug 2024
                    • 20
                    • Philippines
                    After removing pq311 I get ol in ohms measurement of all s&d s&g g&d pins
                    but in diode mode the measurement of souce and gate is 400
                    I remove pq310 same pinout measurement but in diode mode of g&s is 400
                    is this normal? Or shoul i have value of the pinout in ohms mode
                    • mon2
                      • Dec 2019
                      • 14694
                      OL means over limit.
                      Is your meter auto ranging or manual select for the resistance scale? Switch to a higher resistance scale till you see a measurement.
                      Post the resistance values in ohms. Your scale may be k ohms for example, etc.
                      • Kshi
                        • Aug 2024
                        • 20
                        • Philippines
                        Its manual select 2m,200k,2k,200 I tried all settings but not measuring any
                        tried to remove 1st mosfet on donor board and i got readings on it
                        • Sephir0th
                          • Oct 2020
                          • 1289
                          O.L. is fine but only when assuming you made proper contact with your probes. The value in diode mode proves that the Mosfets have not failed open beside diode mode is not suitable for normal resistance measurements.
                          Since a shorted Mosfet normally wouldn't prevent the voltage from passing the 1st Mosfet from Drain to Source, it's time to inspect the charging controller. Most likely the ALW are not coming up, the charging controller doesn't inform the EC via ACOK.
                          And i strongly suggest to inspect other possible related spots for previous work.
                          FairRepair on YouTube
                          • Kshi
                            • Aug 2024
                            • 20
                            • Philippines
                            this is the measurement i got on charging ic
                            ACIN_CHG 4.50v
                            AC_IN 0.05v
                            EC_SMB_DA1 0.02v
                            EC_SMB_CK1 0v
                            N16860695 0v
                            AMON_ISL955 0v
                            BMON_ISL955 0v
                            N16860688 0v
                            PROG_CHG 0v
                            COMP_CHG 0v
                            CCLIM_CHG 1.6v
                            FSET_CHG 0v
                            N16860560 0v
                            CSON_CHG 0v
                            CSOP_CHG 0v
                            ACLIM_CHG 1.3
                            N16860799 0.92v
                            N16860474 18.7v
                            VDD_CHG 5.2v
                            VDDP_CHG 5.2v
                            LG_CHG 0v
                            LX_CHG 0v but sometimes unstalbe 3v to 0v
                            UG CHG 0.6v
                            BST_CHG 4.8v
                            BGATE_CHG 4.2v
                            VBAT_CHG 0v
                            OPCP_CHG 4.8v
                            OPCN_CHG 0.06
                            CMSRC_CHG 0v
                            ASGATE_CHG 0v
                            CSIN_CHG 0v
                            CSIP_CHG 0v
                            GND
                            I cant see any previous work done maybe they only jump 1st mosfet? then jumping that eventually
                            blown the charging ic?
                            • Sephir0th
                              • Oct 2020
                              • 1289
                              Add at least the Pincount or even better, add the correct designations from the schematics. To use the boardview as reference is not sufficient here.
                              • Sephir0th
                                • Oct 2020
                                • 1289
                                EC_SMB_DA1 and EC_SMB_CK1 missing implicates that not only the +3VLP is missing but +19VB too. In your initial post you wrote it is present.
                                Of course such mistakes can lead the approach into the wrong direction. But it's fine since it was advised to check the charging controller anyway. Correct DCIN, ACIN, VDD and VDDP voltage in combination with no ASGATE to drive the Mosfets normally means a dead charging controller... except the Mosfets were replaced with wrong parts.
                                other subtle faults are possible too, like PR304, PR305 failed or low resistance at VDD/VDDP. Yes, voltage measurements are not enough and reveal only half of the picture. We need resistance measurements in addition.
                                • mon2
                                  • Dec 2019
                                  • 14694
                                  AC_IN 0.05v
                                  Review this. This is mated to ACOK on your charger IC pin # 2.
                                  Measure the voltage on PR311.
                                  Remove all power. Measure the resistance across PR311.
                                  ACIN pin #1 has a valid adapter voltage (ACIN_CHG = 4.50v). Based on this voltage, ACOK should be floating since this is an open-drain output. When the line is floating, the 2 resistors @ PR311 & PR313 will build a voltage divider to park this floating line. At this time, the AC_IN signal line is @ 0v. If the charger truly does not like the adapter voltage, the charger IC will pull this line to the logic low = 0v but to me, it is ok and there should be a valid voltage here unless the parking resistors are missing or of the wrong values.
                                  Click image for larger version  Name:	ac_in.png Views:	0 Size:	114.4 KB ID:	3691265
                                  • Kshi
                                    • Aug 2024
                                    • 20
                                    • Philippines
                                    Sorry for the confusion on my post. +3VLP and +19VP were present before I found a jumper wire below the first mosfet. I replaced the mosfet, and now 19V is not passing through the first mosfet. The problem I have now.
                                    I use mdu1511 to replace EMB04N03H. I don't really think if this is compatible.
                                    I attached value of each mosfets
                                    The resistance of PR304 is 0 ohm, and PR305 is 1.5 ohm. The measurement of VDD to ground is 90k ohms.
                                    Is it that one of the resistors is faulty?
                                    • Kshi
                                      • Aug 2024
                                      • 20
                                      • Philippines
                                      PR311 reading is 65Kohms
                                      in ground 95K ohms in both legs
                                      • mon2
                                        • Dec 2019
                                        • 14694
                                        Confirm that VDD_CHG is present on the one side of PR311. This is important. Measure this voltage to ground.
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • FrozenHaxor
                                          Lenovo Ideapad 3 15IIL05 NM-D031 +3VALW missing
                                          by FrozenHaxor
                                          Having an issue troubleshooting this board, it takes no current. PQ100 MOSFET gets 0V on the gate and does not open, when I short it out the laptop powers up. There is 0V on ACDRV from BQ24780, 0V on ACOK.
                                          Now for the fun part, ACOK is pulled up to 3VALW rail, when I short out the PQ100 and power up the laptop, ACOK jumps up to correct 3.3V, as soon as I remove the short across the MOSFET it goes fully dead again. Now my issue is that according to schematic this is a circular logic, I can't have +3VALW without getting power to the PU1101 SY8386BRHC, but I can't...
                                          10-16-2025, 05:58 AM
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
