A2338 820-02020-A | Battery Not Detected/Random Reboots
  • mon2
    • Dec 2019
    • 14753
    Which part is onboard? Is it from the donor or from DK? Either way, can you share the topside part #? There should be a datasheet available for the component.
    • grimacelord
      • Jan 2017
      • 383
      The donor component is currently installed on the board. It was pulled from an identical board. I haven't yet purchased any components for this repair yet.
      The datasheet can be found here
      • mon2
        • Dec 2019
        • 14753
        Yes, I would definitely test with a known good part here. Order a few spares. They are inexpensive.
        The part # LSF0102DQER is the one you want = X2SON package.
        https://www.digikey.ca/en/products/detail/texas-instruments/LSF0102DQER/5178276?gad_source=1&gad_campaignid=17336435733&gbraid=0AAAAADrbLlhEl4sNBDTOAhHifoLIroCfZ&gclid=CjwKCAjwv5zEBhBwEiwAOg2YKETDWhY4f5_B_rsqjxymvlyZ3uvLUqIc7tEYhlVyRAvkeq0zQEAs-RoCW30QAvD_BwE&gclsrc=aw.ds
        • grimacelord
          • Jan 2017
          • 383
          Will do! I will order some today and let you know in a couple of days once I receive it. Thanks!
          • grimacelord
            • Jan 2017
            • 383
            Back again with some new components from DigiKey installed. Some behavior is different, but still not quite right.
            Components Replaced:
            U5150 (RCLAMP3552T)
            UD201 (LSF0102)
            New Behavior:
            With logic board fully installed, power adapter connected, but NO battery connected to logic board:
            I2C_SMC_PWR_3V3_SCL: 3.25V
            I2C_SMC_PWR_3V3_SCA: 3.25V
            Taking same voltage measurement of the same lines WITH battery connected:
            I2C_SMC_PWR_3V3_SCL: 0.607V
            I2C_SMC_PWR_3V3_SCA: 0.76mV
            Since I am now getting the correct voltage on the two battery lines WITHOUT the battery connected (after replacing U5150 and UD201), but then the voltage changes only AFTER the battery is connected to something that isn't acceptable, does that suggest that the battery itself and/or the battery flex cable may now be the culprit or could it be something else with the logic board?
            I feel like we're getting closer...
            • mon2
              • Dec 2019
              • 14753
              Disconnect the battery. While the battery is on your work bench, meter in resistance mode, measure the resistance to the battery ground of:
              I2C_SMC_PWR_3V3_SCL
              I2C_SMC_PWR_3V3_SDA
              These will be on the battery connector itself. We are trying to confirm if the SMBUS interface is defective on the actual battery. Or you can test the same with another known good battery on the logic board.
              • grimacelord
                • Jan 2017
                • 383
                Just wanted to come back and report that a new battery finally fixed that last problem. The battery is now detected by the machine and all is well. So it was a combination of those two components on the logic board, the battery flex cable connector, a new battery, and a new battery flex cable. Everything works as expected now. As always, thanks for the help mon2!
                • Instafixx
                  Macbook A2338 Amp Meter Reboots
                  by Instafixx
                  Namaste.
                  I have a Macbook A2338 that came in for turning on issue. It turned on once when i had it but then again went off. The amp meter but bootloop. The board was clean - no dust - no green .
                  I performed a DFU Revive. Got the error 4042. Assumed BAD SSD. But it turned on , worked well for 1 day and again went off.
                  Anything can be done ?The customer needs data
                  09-27-2023, 02:25 AM
                • bibinskii
                  Macbook Pro M1 (A2338) - Not Charging but Detected and Post
                  by bibinskii
                  A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
                  At first, I thought that this must be a battery issue. I went to replace the battery....
                  07-22-2024, 12:22 AM
                • todordm
                  Macbook A2338 / A2337 - Replace SSD
                  by todordm
                  There are a lot of Video Tutorials how the SSD of A2338 or A2337 can be upgraded. Normally they say you can order the bigger SSD chips (0 and 1) from China. But as far as I understand you can take the SSD chips of one A2337/A2338 and install on another, put to DFU mode, do the recovery, reinstall etc... I tried that several times (tried to upgrade 256GB to 512Gb, then to 1TB, then to another 256Gb)... nothing worked. So my question to the community is: can I just take the SSD chips from one A2338 and intall them on another A2338 (taking care of course of the 0 and 1 positions)? Or I have always...
                  01-17-2024, 03:55 AM
                • EvazX
                  ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                  by EvazX
                  I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                  Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                  For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                  However, after some time, the replacement motherboard...
                  08-25-2025, 06:09 PM
                • spacez
                  XPS 15 9520 - tpm device is not detected - NO ssd detected
                  by spacez
                  I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
                  Service Tag: J2MSHW3
                  |Express Service Code: 41518077843
                  mother board LA-L402P REV 1.0(A00)​...
                  08-18-2024, 10:54 PM
