Lenovo Legion 5 Pro 16ACH6H Water Damage
  • khaahk
    • Dec 2013
    • 820
    • Estonia
    #41
    Originally posted by Andreasbest
    Incredible mess.
    Agree here
    About measurements to take:
    See what voltages are coming up, are 3.3V and 5V stable? Does ram/cpu core get any voltage (if you have oscilloscope would be better to see if there is at least a try to start it).
    Is b+ stable or fluctuating? (if not stable indicates some failure at later stage power rail) etc.
    PL1009 is still the same resistance?
    • Andreasbest
      • Aug 2014
      • 1197
      • Hellas ( Greece )
      #42
      Please tell me exactly where you want to measure 3v and where 5v. PL1009 @ 18ohm
      • khaahk
        • Dec 2013
        • 820
        • Estonia
        #43
        You'll have to make some effort on your own, on the schematic power controllers start from page 89 with charger, then there comes 3v and 5v.
        For B+ you can measure on PR5401, 5V is on PL6202 etc... - you have the schematics and boardview, use them.
        Check which voltages are present, are they stable, what changes after power button is pressed. As you are using original power supply then we can not get information about power consumption to make some conclusions this way.
        Also as this is liquid damage there can be bad connection anywhere on the board, some resistor with damaged contacts and that alone can be the reason for no start. So visual inspection is important.
        Voltage rails are on page 6, after cmos reset the board should start right away after receiving power.
        • Andreasbest
          • Aug 2014
          • 1197
          • Hellas ( Greece )
          #44
          Οκ, PL1009 @ 18ohm is indicating short?
          • khaahk
            • Dec 2013
            • 820
            • Estonia
            #45
            18 ohm might be totally normal resistance for cpu core or integrated graphics controller knowing that it is a low voltage rail. If you have that resistance on B+ or 3/5V rail then this is not normal.
            For now measure voltages on inductors, see which ones are present and stable. Does anything change if power button is pressed, if long pressed does power state change. If you have a power meter use it to see how much power is drawn. Post results.
            You should get some understanding what is going on, just a starter from Rossmann for example.
            • Andreasbest
              • Aug 2014
              • 1197
              • Hellas ( Greece )
              #46
              PR5401 PC6202 PC6210 @ 0.8 but sometimes sparks up to 1.5v and then drops again at 0.8 or lower.
              PL6202 @ 0v
              No reaction when i press the power button.
              4v @ PQ111 and PQ110
              3.3v @ PQ112 PR113 PR115 PQ113 (PIN 3)
              0v @ PR127 RX10 RX8
              Not sure if i'm proceeding correctly, schematics always looked like alien language to me.
              • khaahk
                • Dec 2013
                • 820
                • Estonia
                #47
                You still don't have solid B+ main power rail.
                Resistance to gnd on PR5401 ?
                Measure resistance to gnd on all inductors (PLxxx) and post results.
                • Andreasbest
                  • Aug 2014
                  • 1197
                  • Hellas ( Greece )
                  #48
                  PR5401 to GND 9.5KΩ
                  PLU1 1.5K
                  PL6202 9K
                  PL6201 2.6K
                  PL7901 60K
                  PL3001 0.6K
                  PL5401 33K
                  PL6601 2.5K
                  PL4006 125Ω
                  PL4005 125Ω
                  PL2001 2002 2003 2004 2005 1Ω
                  PL7701 73Ω
                  PL1009 16Ω
                  PL1003 1004 1005 1006 7Ω
                  • khaahk
                    • Dec 2013
                    • 820
                    • Estonia
                    #49
                    Can't find any obvious problems here. Next i would look at the charger again, connect adapter and retake the voltage measurements on every pin. Post a clear picture of charger area (PU5401).
                    • Andreasbest
                      • Aug 2014
                      • 1197
                      • Hellas ( Greece )
                      #50
                      Original psu is 300W and the one i use is 170w.
                      Perhaps this is the problem?
                      • davidebeatrici
                        • Dec 2020
                        • 131
                        • Italy
                        #51
                        I know for sure the motherboard doesn't start without the ID pin. It's indeed possible it may not start if the resistance is not what it expects.
                        From https://www.thinkwiki.org/wiki/Power...#Signal_Pin_2:
                        • khaahk
                          • Dec 2013
                          • 820
                          • Estonia
                          #52
                          Not sure how it would react to 170W adapter, from 90W it does not work. If you have lab supply with enough power and can solder the 8.6K resistance from id pin to gnd then try.
                          Also you had the possibility to charge the battery elsewhere. How does the board work from battery?
                          • Andreasbest
                            • Aug 2014
                            • 1197
                            • Hellas ( Greece )
                            #53
                            Great idea, I have battery analyzer that can charge it. I will try
                            • davidebeatrici
                              • Dec 2020
                              • 131
                              • Italy
                              #54
                              Looks like lower wattage power supplies are supported with a warning on boot, but not sure about the minimum watts required.
Name:	Lenovo Legion 5 15ACH6H dead after windows updates - Sadly, laptops are dying after windows updates 11-22 screenshot.png
                              • Andreasbest
                                • Aug 2014
                                • 1197
                                • Hellas ( Greece )
                                #55
                                I'm almost sure that 170w are enough to just power on the motherboard.
                                I'll try with battery and if not possible i'll go for the external psu with resistor and Lenovo plug.
                                • Andreasbest
                                  • Aug 2014
                                  • 1197
                                  • Hellas ( Greece )
                                  #56
                                  Just noticed that the charger ic is smoking and sparking, ordered a new lot. Probably i damaged it during replacement.
                                    Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook Specification for Upgrade or Repair
                                    This specification for the Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P boardview and NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-07-2024, 04:10 AM
                                    Lenovo Legion 5 Pro 16ACH6H Notebook Specification for Upgrade or Repair
                                    This specification for the Lenovo Legion 5 Pro 16ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 Pro 16ACH6H boardview and 5 Pro 16ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-07-2024, 04:30 AM
                                    LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                    This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                    09-12-2024, 02:30 PM
                                    Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                    This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 05:00 AM
                                    Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                    This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
