Lenovo Legion 5 Pro 16ACH6H Water Damage
  • Andreasbest
    • Aug 2014
    • 1197
    • Hellas ( Greece )
    Hello!
    Today i received a Legion 5 pro with motherboard NM-D562 that suffered water damage, no power at all, no led, no fans, nothing.
    I measure 20v on PQ5401 at pins 5, 6, 7 and 8 but 0v at 1, 2, 3 and 4.
    Is this normal?
    Thanks in advance!
    Schematics and boardview-> https://www.badcaps.net/forum/troubl...95#post3254995
  • Andreasbest
    • Aug 2014
    • 1197
    • Hellas ( Greece )
    bump
    • Andreasbest
      • Aug 2014
      • 1197
      • Hellas ( Greece )
      I have no 3v. I think i get no voltage from PU5401 but not sure, i'm totally dumb in reading schematics.
      If someone is willing to help i'm on the bench now and for the next hours. Thank you!
      • Andreasbest
        • Aug 2014
        • 1197
        • Hellas ( Greece )
        Someone? Anyone?
        • Andreasbest
          • Aug 2014
          • 1197
          • Hellas ( Greece )
          Bump
          • Andreasbest
            • Aug 2014
            • 1197
            • Hellas ( Greece )
            None has the slightest idea?
            • khaahk
              • Dec 2013
              • 826
              • Estonia
              PU5401 gets its power via pd5401.
              Voltages on pin 5, 6, 24, 28 of PU5401
              Resistance to gnd on PR5401
              • Andreasbest
                • Aug 2014
                • 1197
                • Hellas ( Greece )
                Thank you for replying. To make sure i understand, you want to measure all these voltages and check ground resistance on PR5401 ?
                • khaahk
                  • Dec 2013
                  • 826
                  • Estonia
                  Yes
                  • Andreasbest
                    • Aug 2014
                    • 1197
                    • Hellas ( Greece )
                    Yes
                    Sorry for the delay, got a problem.
                    Here are the measurements:
                    PR5401 16Ω on both pins to GND
                    PU5401 voltages:
                    pin5 0v
                    pin6 2.68v
                    pin24 6v
                    pin28 30v
                    • Andreasbest
                      • Aug 2014
                      • 1197
                      • Hellas ( Greece )
                      *pin28 20v
                      • khaahk
                        • Dec 2013
                        • 826
                        • Estonia
                        Measure resistance on pin 5 to gnd. If low ohms, remove 24780s and retest. If it changes to high value change 24780s. If not you might have problem with ec.
                        If originally pin5 to gnd measures high resistance - check pullup resistor re42, if it is ok then change 24780s anyways.
                        • Andreasbest
                          • Aug 2014
                          • 1197
                          • Hellas ( Greece )
                          450KΩ pin5 to GND
                          What is 24780s ?
                          • khaahk
                            • Dec 2013
                            • 826
                            • Estonia
                            PU5401 = 24780S charger ic
                            Change it, most likely at fault.
                            • Andreasbest
                              • Aug 2014
                              • 1197
                              • Hellas ( Greece )
                              Since i must order it and wait 3 weeks for delivery is there any other measurement to take to verify it's faulty?
                              Also if the charger ic is faulty the motherboard should power up if i connect a charged battery, correct?
                              • khaahk
                                • Dec 2013
                                • 826
                                • Estonia
                                I don't know no checks that can be done, it is ic-s internal fault. If mainboard has no further problems then it probably should work from battery.
                                • Andreasbest
                                  • Aug 2014
                                  • 1197
                                  • Hellas ( Greece )
                                  Still dead with fully charged battery. The problem must be somewhere else. Any ideas?
                                  • mon2
                                    • Dec 2019
                                    • 14735
                                    Test the resistance across the 2nd dcin mosfet.
                                    source / drain
                                    source / gate
                                    gate / drain
                                    often 2nd dcin mosfet is defective and takes down the 1st dcin mosfet since they share the gate pins.
                                    no power to the board during these tests.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1197
                                      • Hellas ( Greece )
                                      Thank you but which one is the second dcin mosfet?
                                      • mon2
                                        • Dec 2019
                                        • 14735
                                        PQ5402
                                          Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P boardview and NB LN LEGION 5 PRO 16ACH6H R7 32G1T1T11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 04:10 AM
                                          Lenovo Legion 5 Pro 16ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion 5 Pro 16ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 Pro 16ACH6H boardview and 5 Pro 16ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 04:30 AM
                                          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                          09-12-2024, 02:30 PM
                                          Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
