MacBook Pro M1 13 820-02020 stuck at 5V 0.1A
  • mitchw
    • 136
    • Slovenia
    Board had some light liquid damage, nothing serious, just one bad looking cap that I removed (from PPBUS_G3H to ground), near speaker amps.
    There was no corrosion as such, just few tiny spots, really minor.
    The board is stuck at 5V, it draws 0.1A all the time. Only at poweron the amperage surges up to about 0.15-0.18A, then it settles at 0.1A.
    I put it in DFU and it didn't do anything, wasn't detected on other machine.
    Voltages all seem OK near the CD3217 chips, all LDOs are present, also no liquid damage was nowhere around those.
    But measuring other voltages, all of them were present when I checked the PP5V_S2 which is missing.
    PPBUS_G3H is 12.3V, PP3V8_AON is 3.8V,...
    So this is about what I checked, but don't know what to check next. I am not sure if the problem is with USB-C detection or it might be with CPU or something completely else
  • mon2
    • 14332
    Remove all power. Meter in resistance mode. What is the exact resistance to ground of PP5V_S2?
    • mitchw
      • 136
      • Slovenia
      Resistance is over 2M ohms. Diode drop is 0.315.
      PP5VS2_EN is also missing
      • mitchw
        • 136
        • Slovenia
        Found a corroded resistor: RD531, replaced it, no change. Also that cap that was shorting PPBUS_G3H was CR604 which I removed, but it should work without it.
        Next, I was checking all the LDOs and discovered that I am missing one voltage: MPMU_VREF_ADC, which is at 0V. All other voltages (except for PP5V_S2) are all present.
        MPMU_VREF_ADC is not shorted and it reads 0.590 in diode mode.
        So where to look next? Nothing else is looking crusty or corroded.
        • mitchw
          • 136
          • Slovenia
          So in essence, what I found and corrected:
          - CR604 was badly corroded and removed
          - RD531 was O/L also corroded and replaced
          - CD3217 area wasn't affected at all, every LDO voltage measure spot on
          Voltages:
          -All voltages expect the following are present:
          -PPBUS_G3H is 12.3V (should be 12.6V or more)
          -PP5V_S2 is missing and not shorted
          -PP5VS2_EN is also missing (generated by U8100)
          -On the U8100 all LDO voltages are present, except for MPMU_VREF_ADC
          -U7700 has all the output voltages present
          So from what I have gathered, the U8100 might be at fault, but I've seen other threads of similar U8100 issues (missing MPMU_VREF_ADC), and replacing it with another U8100 didn't solve it.
          • Bmet
            MacBook Pro 13 inch A2238 M2 stuck on 5V
            by Bmet
            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
            04-02-2025, 05:02 PM
          • Steven Pieter
            Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
            by Steven Pieter
            hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
            11-24-2024, 10:02 AM
          • DATATECH85
            Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
            by DATATECH85
            I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
            The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
            I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
            However, I can't work out exactly why I don't have the PPBUS_G3H rail.
            Here are the values...
            07-24-2024, 06:34 AM
          • martyjelen
            Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
            by martyjelen
            Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
            PP3v3_G3H_RTC_X is present - 3,3V
            PP3v3_G3H_SOCPMU is present - 3,3V
            ​What else should I check?
            Thank you for your help.
            05-05-2025, 01:34 AM
          • duwane
            MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
            by duwane
            Hi All.
            I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
            Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
            After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
            Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
            10-17-2023, 07:48 PM
