2020 MacBook Pro M1 bootlooping after repair.
  • Gueric
    • Feb 2025
    • 69
    • France
    Basically, this never opened before MacBook Pro had some liquid damage around a few keyboard backlight components, that I replaced. Turns out it wasn’t the actual issue, the actual issue was a defective CD3217.
    Removed it, replaced it. Laptop booted fine, I erased it, installed a new macOS version, checked battery health, speakers, screen etc. Turned it off to put everything back together, turned it on again, and it started bootlooping.
    Chime, shows apple logo, then a progress bar, and when it fills at about 1%, reboots. Back to the Apple logo, progess bar almost empty, reboots a 3rd time, then shows an exclamation mark with the /restore link, and the fan at full speed.
    When shown this exclamation mark, long pressing to shut down the Mac makes it pulls 1.5A, possibly charging the battery.
    I don’t know what to look for as I’m very confused.
    both CD3217s pull 20v and behave the same. Probed a few SSD lines (2v5, 0,8v, 1,25v) and they’re not shorted.
    The bare board also bootloops. Interestingly, when plugged into my Mac (so, 5v) the board alone pulls a little bit of current, reboots, then stays at 5v 0A. No bootloops.
    thank you very much in advance.
    If you are mon2, then hey mon2.
  • mon2
    • Dec 2019
    • 14103
    LOL. Hey. I have no life and a few minutes before my Netflix binge watching.
    Check your trackpad cable. There are sensors in the trackpad and fan at full speed is often linked to the trackpad. Be sure the contacts on the flex cables are clean. Do inspect them for debris, etc.
    • Gueric
      • Feb 2025
      • 69
      • France
      Hey mon2 I'm not gonna complain if it allows me to fix my stuff and learn lol.
      I checked for everything, and I have a few interesting things to add.
      It is rebooting 3 times, then shows a restore exclamation mark, and from this point stays on the restore screen and never boot loops again and pulls way more current (1.5A when plugged into the wall, and 2.5A when plugged into my other Mac at 5V) CPU is cold, NANDs too. I don't think the issue is with the CD3217s. Also, when at 20v it pulls very little current during the boot loop thing.
      Also, fan is not spinning at all anymore, and the trackpad does indeed click on the restore screen.
      • Gueric
        • Feb 2025
        • 69
        • France
        Small update. I tried to reflow both of them, and its even worse now. I believe one or both (the one i replaced and tje one i didnt replace) were defective from the start. It’s now pulling 5v, a bit more current at 100-280mA, and bootloops way faster and more. I ordered a dead M1 and ill update when both CD32s have been replaced.
        Good binge watch to you :p
        • mon2
          • Dec 2019
          • 14103
          Review the ldo rails of each pd controller.
          • Gueric
            • Feb 2025
            • 69
            • France
            so, mon2 I just checked almost EVERY single pin of BOTH CD32s using diode mode. everything looks fine.
            I just realized that now only the CD3217 I didn't replaced negotiates 20V. the other, that I replaced and that worked for a few hours, negotiates 5V at 0A, and doesn't make the board boot loop. So I guess it's defective because the reball was good and I even tried a reflow.
            Let me know what you think
            • Enzo150i
              MacBook A2442 exclamation mark after oxydation
              by Enzo150i
              I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
              The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
              Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
              We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
              06-29-2025, 01:26 PM
            • sjsul
              Macbook M1s exclamation mark not seen in DFU
              by sjsul
              Hi colleagues,
              I have a situation with 2 Macbooks M1, 1x A2337 and 1x A2338. I will post below the symptoms and what I have tried until now
              - They both power on and display the exclamation mark 1 second after displaying the Apple Logo
              - They both try to enter Recovery but after restart they loop in the step above, showing the exclamation mark
              - They both enter DFU but are not recognized by the other computer. Also tried force DFU, bot have voltage on SOC_DFU_STATUS. Still not found by other computer in Apple Configurator or Finder, used more cables, TBT3 and...
              04-11-2025, 01:01 AM
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
            • Featurea
              Macbook air a1932 bootlooping after airport control
              by Featurea
              once again I am here with problems with my macbook. After successful repair, when everything was working fine, I took my macbook air to the airport and flight with it in carry-on baggage. Firstly after landing it was working fine, but suddenly it shuted down and started bootlooping to the apple sign. I managed to run it normally throught SMC reset, but problem was going back untill SMC reset stopped working. Now Macbook is bootlooping in normal start, I can't go to recovery, I tried internet recovery, but after fully loaded download bar it switches off.
              I have...
              06-21-2022, 02:20 PM
            • modtool
              Macbook Pro A1989 fallen, reboots if touchbar connected
              by modtool
              Hi to all,
              the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
              Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
              11-10-2023, 07:42 AM
