Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
  • G_sene
    • Jul 2023
    • 76
    • Brasil
    #121
    Originally posted by mon2
    Ok. What is the exact voltage on the gate pin of PQ303?
    See attached. PQ303 = P-channel mosfet. P-channel mosfets require that the gate voltage be lower than the voltage being passed between source / drain pins to ENABLE.
    The resistors mated with the gate pin on PQ303 work together to build a voltage divider to lower the gate voltage. Respectively, when the gate voltage is LOW enough, the mosfet is being requested to be ON to pass the battery voltage onto the main power bus.
    This PQ303 should be enabled when the power adapter is removed. Otherwise should be disabled.
    When you have BOTH power adapter and battery connected, PQ303 should be disabled. Confirm it.
    I put the jumper back on, but now I can't charge the battery from the power supply anymore.
    • mon2
      • Dec 2019
      • 14551
      Which jumper? Vin jumper? Review post # 120 and share the measurements.
      • G_sene
        • Jul 2023
        • 76
        • Brasil
        #123
        Only adapter:
        Source - 19v
        Drain - 1.89 (????)
        Gate - 19v
        Battery and adapter:
        Source - 19v
        Drain - 13.55v
        Gate - 19v
        Only battery:
        Source - 12.85v
        Drain - 12.85v
        Gate - 0v
        With VIN jumper PR304 has 19v in the both sides
        • mon2
          • Dec 2019
          • 14551
          Source - 19v
          Drain - 1.89 (????)
          Gate - 19v
          Mosfet may be leaking or is from the high / low side charging mosfets. Remove all power. Meter in resistance mode.
          Measure the resistance across this mosfet:
          source / drain
          source / gate
          gate / drain
          Post each measurement.
          • G_sene
            • Jul 2023
            • 76
            • Brasil
            #125
            source / drain
            source / gate
            gate / drain
            Source/drain - 1.76M
            Source/gate - 820k
            Gate/drain - 515k
            • mon2
              • Dec 2019
              • 14551
              Mosfet looks ok.
              Source - 19v
              Drain - 13.55v
              Gate - 19v
              Battery should be charging. What does Windows show in this case?
              • G_sene
                • Jul 2023
                • 76
                • Brasil
                #127
                Mosfet looks ok.
                I'll check.
                But isn't PQ303 an P-channel?
                Shouldn't the gate voltage be lower?
                • mon2
                  • Dec 2019
                  • 14551
                  Correct, PQ303 is P-channel. When both, the adapter & battery are connected, this mosfet should be OFF so the gate voltage is the correct value to remain OFF.
                  This mosfet should only be ON when the battery is the only power source. Then the gate voltge should be lower to enable, which it is.
                  • G_sene
                    • Jul 2023
                    • 76
                    • Brasil
                    #129
                    SOLVEEEEEEED =D
                    Thank you
                    I thought it wouldn't work because the gate was at 19v and the drain was very low.
