Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
  • mon2
    • Dec 2019
    • 14685
    You cannot measure resistance if the power is on.
    Does the laptop turn on with the power adapter? What does Windows show for the battery?
    • G_sene
      • Jul 2023
      • 76
      • Brasil
      #102
      The adapter powers the laptop normally.
      The only thing is that the charger icon doesn't appear.
      I'll see what CMD tells me about the battery.
      The battery also works if I remove the adapter; I even charged it a bit using the power adapter.
      • mon2
        • Dec 2019
        • 14685
        Watch this video and test this method:
        https://www.youtube.com/watch?v=HV1iWoEstLA
        • G_sene
          • Jul 2023
          • 76
          • Brasil
          #104
          I tried uninstalling the driver in the driver manager, but it didn't change anything.
          The Lenovo website doesn't show a battery driver for my model.
          • mon2
            • Dec 2019
            • 14685
            The Lenovo G40-80 battery driver, also known as the Advanced Configuration and Power Management Interface (ACPI) driver, can be updated or installed by downloading it from the Lenovo support website. You can either manually download the driver from the website or use the "Detect Product" feature to automatically scan your system for the correct drivers.
            To manually download and install the driver:
            1. Identify your operating system: Make sure you know whether you have a 32-bit or 64-bit version of Windows.
            2. Go to the Lenovo support website:Navigate to the Lenovo support page for the G40-80 laptop.
            3. Locate the Drivers & Software section:Find the section for drivers and software downloads.
            4. Find the ACPI driver: Look for the "Advanced Configuration and Power Management Interface (ACPI) Driver".
            5. Download the driver: Download the appropriate driver file for your operating system.
            6. Install the driver: Follow the on-screen instructions to install the driver.
            To use the "Detect Product" feature:
            1. Go to the Lenovo support website:Navigate to the Lenovo support page for the G40-80 laptop.
            2. Find the Drivers & Software section: Find the section for drivers and software downloads.
            3. Click "Detect Product": Follow the instructions to download and install Lenovo Service Bridge if needed, which will automatically detect your system and find the correct drivers.
            4. Download and install the ACPI driver: The website will then display the available drivers, including the ACPI driver. Download and install it.
            • G_sene
              • Jul 2023
              • 76
              • Brasil
              #106
              I'll test this!
              I have a question: shouldn't pin 5 (ACOK) on my BQ be at 3.3V when the adapter is plugged in?
              I checked it, and it's zero. It seems the BQ doesn't release a charge if there's no ACOK; it's just recognizing that a charger is connected.
              • mon2
                • Dec 2019
                • 14685
                ACOK is ACPRN. ACPRN is pulled up through a resistor to the REGN voltage so this means ACOK should be ~6v when the adapter is docked and is accepted to be OK.
                See attached. Confirm you have a pull-up resistor onboard. Confirm that the REGN voltage = BQ24737_VDD is present on the other side of the resistor @ PR325.
                REGN should be ~6 volts.
                • G_sene
                  • Jul 2023
                  • 76
                  • Brasil
                  #108
                  6v on the side of BQ24737
                  • mon2
                    • Dec 2019
                    • 14685
                    What is the voltage to ground of ACDET pin #6?
                    • G_sene
                      • Jul 2023
                      • 76
                      • Brasil
                      #110
                      2.61v
                      • mon2
                        • Dec 2019
                        • 14685
                        The designers at TI are bipolar. On this 737 charger ic, it is ACOK# so this signal will be active low when the adapter is OK. So you are fine here so far.
                        What is the voltage of PACIN?
                        • G_sene
                          • Jul 2023
                          • 76
                          • Brasil
                          #112
                          PR309 side of PQ307 5.97v
                          PR309 side of PACIN 3.55v
                          • mon2
                            • Dec 2019
                            • 14685
                            Not sure I follow the measurements.
                            See below.
                            Measure the voltage to ground of each of the highlighted labels.
                            PACIN is ~6v?
                            Post each.
                            • G_sene
                              • Jul 2023
                              • 76
                              • Brasil
                              #114
                              See below.
                              PACIN is ~6v?
                              Post each.
                              Click image for larger version  Name:	test_points.png Views:	0 Size:	121.9 KB ID:	3695485
                              Sorry, I just took a better look at the board. The PACIN side is 3.55V, and the 5.97V side is the PQ307 gate side.
                              ACOFF 0V
                              BATT_OUT 0V
                              (Measuring with only adapter connected)
                              • G_sene
                                • Jul 2023
                                • 76
                                • Brasil
                                #115
                                • mon2
                                  • Dec 2019
                                  • 14685
                                  Weird values.
                                  PACIN is @ 3.55V on PR309 but is 5.97V @ the gate of PQ307? The voltage should not increase at the gate unless someone is leaking.
                                  Flux and remove this dual mosfet. PACIN voltage should be similar on each side of the resistor of PR309.
                                  Do you have more of these dual mosfets?
                                  • G_sene
                                    • Jul 2023
                                    • 76
                                    • Brasil
                                    #117
                                    Weird values.
                                    I just replaced it, so I now have 3.25V on both sides.
                                    Remember that VIN jumper for PR304? Will I need to keep it? Because I don't have VIN on that resistor yet.
                                    • mon2
                                      • Dec 2019
                                      • 14685
                                      Yes, PR304 requires the Vin voltage.
                                      • G_sene
                                        • Jul 2023
                                        • 76
                                        • Brasil
                                        #119
                                        Click image for larger version  Name:	vin.png Views:	0 Size:	100.5 KB ID:	3695670
                                        Okay.
                                        So now I need to rewire the PR304 jumper and test if anything changed.
                                        But what's strange to me is that even with the VIN jumper on PR304, the PQ303 gate still stayed low.
                                        • mon2
                                          • Dec 2019
                                          • 14685
                                          Ok. What is the exact voltage on the gate pin of PQ303?
                                          See attached. PQ303 = P-channel mosfet. P-channel mosfets require that the gate voltage be lower than the voltage being passed between source / drain pins to ENABLE.
                                          The resistors mated with the gate pin on PQ303 work together to build a voltage divider to lower the gate voltage. Respectively, when the gate voltage is LOW enough, the mosfet is being requested to be ON to pass the battery voltage onto the main power bus.
                                          This PQ303 should be enabled when the power adapter is removed. Otherwise should be disabled.
                                          When you have BOTH power adapter and battery connected, PQ303 should be disabled. Confirm it.
