Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
What is the power rating of the adapter being used to power this unit? Did the same adapter function before to charge the laptop?
Review this thread:
https://www.badcaps.net/forum/troubl...esistor-valuesComment
Review this thread:
20v - 4.5a
90w
I didn't ask if this charger was used before.
According to the customer, the laptop no longer turned on and was stored without working.
Another observation, when the charger is plugged in with the battery, it makes a ticking noise, it sounds a lot like a clock, something like that.Comment
Go back to the DCin mosfets @ PQ301 / PQ302.
Remove all power. Meter in resistance mode.
Measure the resistance across:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)
Post each measurement for PQ301 and also PQ302. When powered from battery, the internal diode inside of PQ302 may conduct and present the voltage onto source pins (1-2-3) but this voltage should not be present on the drain pins (5-6-7-8) of PQ301 (with battery only as the power source). Both of these mosfets are suspects.
Update - Long thread. The above DCin mosfets are P-channel so if their gate voltage is lower than the voltage being passed through source / drain pins then yes, they will both enable ON. The gate voltage @ 5volts (confirm if still true) implies that the resistor based voltage dividers on the gate pins are active. We need to go back and study the mosfets that enable / disable these resistors. With only the battery installed, the gate voltage divider resistors on these P-channel mosfets should be disabled. Then the gate voltage, even if passing through the internal diode will disable these P-channel mosfets.Last edited by mon2; 07-11-2025, 07:31 AM.Comment
Update - Long thread. The above DCin mosfets are P-channel so if their gate voltage is lower than the voltage being passed through source / drain pins then yes, they will both enable ON. The gate voltage @ 5volts (confirm if still true) implies that the resistor based voltage dividers on the gate pins are active. We need to go back and study the mosfets that enable / disable these resistors. With only the battery installed, the gate voltage divider resistors on these P-channel mosfets should be disabled. Then the gate voltage, even if passing through the internal diode will disable these P-channel mosfets..
PQ301
source (pin 1) - drain (pin 8) - 544k
source (pin 2) - drain (pin 7) - 543k
source (pin 3) - drain (pin 6) - 543k
source (pin 1, 2, 3) - gate (pin 4) - 200k
gate (pin 4) - drain (5, 6, 7, 8) - 343k
PQ302
source (pin 1) - drain (pin 8) - 1M
source (pin 2) - drain (pin 7) - 1M
source (pin 3) - drain (pin 6) - 1M
gate (pin 4) - drain (5, 6, 7, 8) - 390k
Only with the battery plugged in, I still have 5v at the gate of PQ301 and PQ302.
I'll measure it again.
But before replacing the PQ303, it looked like this:
With charger and no battery:
PQ301 and PQ302
Pins 1, 2, and 3 = 20V
Pin 4 = 9V
Pins 5, 6, 7, and 8 = 20V
With battery and charger:
PQ301 and PQ302
Pins 1, 2, and 3 = 14V
Pins 4 = 5V
Pins 5, 6, 7, and 8 = 14V
Another detail: the 14V battery voltage reaches the charger input! I don't think this was supposed to happen.Comment
I replaced the PQ301 and it still doesn't work.
The charger isn't recognized, and the voltage on pin 1 of the jack is 14V.
Oh, I managed to test another charger with a lower amperage, but it wasn't identified either.
Bad battery?
Strange that it doesn't even identify the charger, and the computer remains connected only to the battery.Comment
apply a resistor to ground on the adapter pin on the logic board and test again. Use a value close to the ones used by the poster of the above thread.Comment
560 ohm resistor on pin 3 of the jack (ID pin) and the other terminal to ground.Comment
Remove all power. Unplug the adapter from the wall. Measure the resistance between the center pin and the ground on the adapter cable. Want to know what resistance is on the id pin from the factory.
see here:
https://superuser.com/questions/1246...apter-slim-tip
see here:
https://superuser.com/questions/1246...apter-slim-tipComment
It had 1.44v before putting the extra resistorComment
by paolottoLenovo 80e5 g50-80 ACLU3/ACLU4 NM-A361 rev.1.0
hello I would like some help, my laptop Lenovo 80e5 g50-80 ACLU3 / ACLU4 NM-A361 rev.1.0 does not turn on. when I insert power the led4 flashes and the fan moves a little. I only found the diagram pdf 2014-09 -10 REV0.4. I would need for BoardViewer the version for my ACLU3 / ACLU4 NM-A361 rev.1 and also schematic pdf. Also doing measurements with the multimeter I find on the line + 1.35_VGS to ground 6.06 ohm. According to me too low.
am I facing a short circuit?
that line affects the rams soldered on the board
thank... -
by zakiyyHello,
Lenovo G50-80 (ACLU3/ACLU4 UMA NM-A362) Rev 1.0
With battery laptop work perfectly ! But with charger no power and not charging ! What can be the problem??
Direct from Charger PIN no connect to laptop: 20.v
PQ301 (4407A)
Drain: 20v - 19v 17v fluctuating
source: 19v - 18 -16v fluctuating
Gain: 19v - 18 -16v fluctuating
PQ302(4483a)
Drain: 2.5v then 5 then 10v then 11v sometimes18 then again 2.5v again and again..
Gain: 19v - 18 -16v fluctuating -
by dariusgcHello, someone have Lenovo G50-80 (ACLU3/ACLU4 NM-A361 Rev.:1.0) schematic?
Channel: Schematic Requests ONLY!
by maurovaleroForum this lenovo just charge when is off and when the battery is nearly 50% laptop shut down
Any idea how start the revisión thx -
by hispeckHello, can anyone help please....Lenovo G50, PL701 and PL303 short to GND laptop dead
- Loading...
