Friend messed up my laptop motherboard while working on my bench
  • Geeker007
    • Jan 2025
    • 20
    Hi All,
    So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
    So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
    I have not tried putting power as of now to the motherboard, fearing it might burn something as components are missing.
    I think the motherboard is shorted now. I know some basics from Youtube videos but not so much into motherboard repair. Can someone please guide me here. It looks like from the below image one pad is removed, two of them are shorted and I am not able to remove the solder on the two pads that look like shorted and are shorted too when check with multimeter. What are these components here that are missing?
    Below the PD Controller (Not Sure if it is PD controller) some caps are also missing.
    Can you guys help me with repair? Which components I should order to get them replaced.
  • m1ch43lzm
    • Mar 2019
    • 948
    • Peru
    Start here: https://www.badcaps.net/forum/troubl...r-s-guidelines
    Brand/model of laptop? Board model number? That info will be needed to find schematics/boardview if available
    • Geeker007
      • Jan 2025
      • 20
      Sorry my bad. I forgot to mention the Laptop model. Its a Lenovo ThinkPad T14 Gen 3 Type 21BS. Can someone please help me out in finding the components from schematics.
      • m1ch43lzm
        • Mar 2019
        • 948
        • Peru
        Schematics and board view here Posts #2 and #3
        https://www.badcaps.net/forum/troubl...atic-boardview
        Type 21BS is T14s gen 3
        Check if it says NM-E091 on the silkscreen, near the onboard RAM
        What's missing:
        - C5401, C5402, C5403: 0.22uF 6.3v X5R 0201, on the data lines that go to the Thunderbolt IC
        - C5503: 2.2uF 6.3v X5R 0402, it goes to a ball under the Thunderbolt IC, can't tell if there's a diagonal trace that goes to it under the black glue in the corner of the Thunderbolt IC/L5501
        - C5506: 2.2uF 6.3v X5R 0402
        - C5507: 10uF 6.3v X5R 0402, in parallel with C5506
        - R2206 (next to L5501): 10 ohms 0201, this one is critical as it goes to the BIOS
        • Geeker007
          • Jan 2025
          • 20
          Great, thanks. One more thing, just got to know he did try to start it by plugging in power and nothing happened, no power? Anything bad could have happened here? No power, because resister R2206 for BIOS is missing?
          Also guide me to find the trace for the pad that is missing, that is C5503, right?
          Also, how can I remove that short on C5506 and C5507, I tried my best but still not able to. I have ordered hot air solder station, may be that would help here?
          I have a spare board, can I replace capacitors at-least from that board? How about resistor? Can I take that also somehow from the spare board?
          Sorry I am new to repair, that is why so many questions, but I am trying to learn.
          • m1ch43lzm
            • Mar 2019
            • 948
            • Peru
            Hard to tell if there's no secondary damage
            For C5503 I can barely see a bit of trace, I don't know if it's that one, I marked it with purple what I think it is, as I can't see a via on the ripped pad that goes to the other side of the board, and there's black glue around it that Lenovo likes to use on their buards
            It isn't connected to the inductor L5501
            You'll need a very fine wire, thinner than a hair for this
            Depends how you're measuring the short, and how many ohms
            Is it from top to bottom or from left to right?
            Those caps are connected in parallel, in the schematics
            Depends whether the spare board you have is the same model, or different
            If it's a dead board from the same model, sure, otherwise you have to search the schematics for your donor board and look for the same values/size if available, sometimes you won't find the same values or sizes
            For the resistor, better order several, you'll lose them easily as they're the size of a flea, also they're very difficult to solder with an iron,
            Since you're in the USA you have digikey and mouser
            It will depend on your skills and equipment, you also need a microscope, a good soldering station with temperature control, with various tip sizes, hot air station, fine tip tweezers
            • m1ch43lzm
              • Mar 2019
              • 948
              • Peru
              Sorry, upload failed from my phone
              Here it is
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • Cysko
                Lenovo IdeaPad Gaming 3 15ARH05 not charging after repair
                by Cysko
                Hello everybody,
                One of my friends brought me his brother's laptop to repair, I'm the third person who put the hands on this laptop (he tried to convince his brother to take it to me for the ram upgrade, dust cleanup and thermal paste replacement but he wanted to make it to his university friend... sorry if I say that, but we saw the result).
                The laptop is a Lenovo IdeaPad Gaming 3 15ARH05 with AMD Ryzen CPU and Nvidia GPU.
                I'm going to give a quick recap of what happened before I got this laptop for repair to make clear the situation.
                A friend of his brother...
                11-24-2024, 07:30 PM
              • Ovanes SMD
                HP Envy 13-BF0013DX Laptop Motherboard Intel® Core™ i7-1250U CPU 8GB N15665-001 I messed up bad
                by Ovanes SMD
                Can someone tell me how i can locate and what is the most cheapest way to find this voltage regulator. College student. discovered repairs and fell in love with it. I connected a 12 volt motor to my 5volt usb port and the motherboard stopped working charging no lights nothing. I took it apart, good at doing that bad at putting it back together"joke" sortve.
                I attached a picture please if someone can tell me what that part is and how i can get it i have a soldering and air gun. Not in a rush. The reason why i need to change this is because i accidently disconnected the battery while...
                08-24-2024, 07:04 PM
              • Archimedes
                HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                by Archimedes
                Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                Fans are spinning. Blindly could install windows11 and got the device manager...
                07-30-2024, 05:14 PM
