HP16 DAG3MMB3AAO REV A No power on, no led charger
  • mon2
    • Dec 2019
    • 14662
    Remove all power. Measure the resistance from pin #4 (ACDRV) on the charger IC to the gate pins on each of the DCin mosfets (PQ8200, PQ8201, PQ8202). This should be ~4k ohms.
    Measure the resistance across the DCin mosfets (PQ8200 PQ8201 - they are in parallel so only one needs to be checked:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8) ; use resistance mode checking not diode mode for these tests
    Then repeat for PQ8202.
    Post each measurement.
    • judamex
      Active Member
      • Jan 2021
      • 186
      • Mexico
      For some reason, when I touched pin 4 of the PQ8202 MOSFET, it gave me pin 1, 2, and 3 readings for the PQ8200 and PQ8201 MOSFETs. When I removed it and applied power to the board, ACDRV magically appeared. The MOSFET on the outside gave me good readings. But just in case, I replaced it with an identical AONR32314, and everything works perfectly now.
      I really appreciate your help, and with that, I'll close this post.
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
