HP16 DAG3MMB3AAO REV A No power on, no led charger
  • judamex
    Active Member
    • Jan 2021
    • 183
    • Mexico
    I have an HP 16 DAG3MMB3AAO REV A. The charge LED doesn't turn on.
    So far, I've checked the three input MOSFETs, and all three seem to be in perfect condition. The charge IC is a BQ24781. The voltages I've checked are:
    VCC: 19V
    REGN: 6V
    ACDET: 2.45
    ACOK: 2.85
    It's striking that I don't have voltages on the ACP, ACN, and CMSRC.
    I'm a bit stuck on how this controller works and why it won't turn on.​
  • mon2
    • Dec 2019
    • 14117
    Reference:
    https://www.youtube.com/watch?v=L2eu...thraLaptopCare
    What is the voltage to ground of ACDRV?
    Remove all power. Meter in resistance mode. Measure the resistance to ground of ACP. Then the resistance to ground of ACN.
    Finally, measure the resistance between the pins ACP and ACN. Do so with the meter probes directly on the ACP and ACN pins. We are interested in the full path resistance of these 2 pins. Post each measurement.
    If you have a schematic, post the link to the schematic but only share the schematic inside the sub-forum for schematics.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Since CMSRC is missing,ACDRV has to be low only. ACDRV goes high only when you have ACDET/ACOK and CMSRC present.
      How you checked the DC-IN mosfets? Please share the readings in resistance mode between
      01.Drain-Source
      02.Drain -gate
      03.Source-Gate
      • Sephir0th
        • Oct 2020
        • 1282
        And the share model of the DC-IN Mosfets when they are fine. Absolute possible that these are NOT controlled by the charging controller if they are P-Channel.
        FairRepair on YouTube
        • judamex
          Active Member
          • Jan 2021
          • 183
          • Mexico
          I am guided by the following schematic diagram
          These are the mosfets on the input line
          • judamex
            Active Member
            • Jan 2021
            • 183
            • Mexico
            01.Drain-Source
            02.Drain -gate
            03.Source-Gate
            Mosfet 1 diode mode
            Drain (R) - Source (B)= .OL
            Drain(R) Gate(B)=.OL
            Source (R) Gate(B)=0.592
            Mosfet 2 diode mode
            Mosfet 3 diode mode
            Drain (R) - Source (B)= 1.8
            Source (R) Gate(B)=0.590
            • judamex
              Active Member
              • Jan 2021
              • 183
              • Mexico
              Originally posted by mon2
              Reference:
              ACDRV (pin4) its on = 0.010V
              Resistence between pin APC and ACD is 0.9 ohm
              • mon2
                • Dec 2019
                • 14117
                Between ACP & ACN?
                What is the resistance to ground of ACN?
                • judamex
                  Active Member
                  • Jan 2021
                  • 183
                  • Mexico
                  Between ACP & ACN?
                  yep, between ACP(pin1) & ACN(pin2) = 0.9ohm
                  resistance for ACN(Red) to GND(Black) =15.45k
                  • mon2
                    • Dec 2019
                    • 14117
                    Using the lowest resistance scale on your meter, touch the probes together. What is the resistance?
                    • judamex
                      Active Member
                      • Jan 2021
                      • 183
                      • Mexico
                      Touching the 2 probes, this is the reading I got on the lowest measurement my multimeter has.
Name:	WhatsApp Image 2025-06-16 at 9.46.44 PM.jpg
                      This is the reading by touching ACN(Pin 1) ACP (pin 2)
Name:	WhatsApp Image 2025-06-16 at 9.46.44 PM (1).jpg
                      • mon2
                        • Dec 2019
                        • 14117
                        Measure each leg of the pcb traces. Measure ACP pin to the entry of the current sense resistor. It should 0R ohms. Repeat with ACN to the other side of the same resistor. Should be 0R ohms again. We are assuming the posted partial schematic is the same as your board.
                        • judamex
                          Active Member
                          • Jan 2021
                          • 183
                          • Mexico
                          the resistance between ACN (Pin1) and the sensing resistor (PR8200) is 0.6 as is ACP (Pin2) with (PR8200) is 0.6
                          • Sephir0th
                            • Oct 2020
                            • 1282
                            ACDET is barely on the border of showing a acceptable voltage (2.4V min.) So maybe worth to take a look here and see what happens when higher voltage (2.6V - 2.7V) reaches this pin.
                            Other than that the BQ24781 are known for notorious failing. So I guess the "Brute-force" method, so simply to replace it would be a option here. Iirc it is interchangeable with BQ24780S.
                            • judamex
                              Active Member
                              • Jan 2021
                              • 183
                              • Mexico
                              I replaced it with a BQ24780S and the conditions remain exactly the same. How could I increase the AC voltage? It's currently 2.49. Could I remove or change the value of any resistors?
                              • mon2
                                • Dec 2019
                                • 14117
                                Yes.
                                1) Review the calculator here:
                                https://learn.sparkfun.com/tutorials...e-dividers/all
                                2) Use 19v as input and the resistor values onboard your logic board.
                                Use this video as guidance:
                                https://youtu.be/L2eurrCKT2k?t=327
                                3) Based on the video and shown typical resistor values, the ACDET should be ~2v59. Locate the resistors on pin # 6 (ACDET) of the charger IC.
                                4) Carefully flux and remove the resistors to measure their resistance. Compare the values to the YT video. To raise the voltage, use a lower resistance value for the low side (the resistor that is going to ground) resistor. Be sure to stuff the next resistor value into the above calculator to understand the expected voltage. Do not power up without the resistors in place and be sure the final voltage is within spec for this charger IC (use the public datasheet for the BQ24780S to understand this specific charger IC).
                                • judamex
                                  Active Member
                                  • Jan 2021
                                  • 183
                                  • Mexico
                                  Yes.
                                  I changed both resistors to 470k and 75k respectively, obtaining 2.56V in ACDET, but the result is the same, neither the charging LED lights up, nor is there any change.
                                  • judamex
                                    Active Member
                                    • Jan 2021
                                    • 183
                                    • Mexico
                                    I changed them again, now I put the first resistor as 430k and the second with 75k, getting 2.71V but still nothing happens, there is no LED and there is no ACDRV, nor ACP or ACN
                                    • mon2
                                      • Dec 2019
                                      • 14117
                                      Ok.
                                      what is the resistance to ground on ACN pin? No power to the board while testing resistance or diode mode.
                                      what is the voltage to ground of:
                                      acok
                                      regn
                                      vcc
                                      cmsrc
                                      on the charger ic?
                                      • judamex
                                        Active Member
                                        • Jan 2021
                                        • 183
                                        • Mexico
                                        Ok.
                                        acok
                                        regn
                                        vcc
                                        cmsrc
                                        on the charger ic?
                                        The resistance between "acn" and GND: 15.5K.
                                        The voltage at the following points is:
                                        acok: 2.88V
                                        regn: 6.07V
                                        vcc: 19.32V
                                        cmsrc: 0.015V
                                        acdet: 2.7v
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • cind12
                                          GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                          by cind12
                                          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                          Resistance on 12V 4K ohms (Power present when on)
                                          Resistance on 12V PEX 4K ohms...
                                          12-08-2023, 09:09 AM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
