Asus Eee PC 1005PE the battery isn't charging
  • samtron786
    • Aug 2016
    • 157
    • germany
    Hello everyone
    Hello, the problem is that after connecting the power adapter, the power supply flashes and doesn't charge the battery. Interestingly, it's causing a short circuit. So I decided to open the notebook to check. I'm missing the circuit diagram.
    Greetings
    Thank you very much​
  • mon2
    • Dec 2019
    • 14025
    Test with a known good battery. Source one from Amazon or similar and return it if it is not required.
    • samtron786
      • Aug 2016
      • 157
      • germany
      Yes, I already ordered one, unfortunately, the same problem.
      • samtron786
        • Aug 2016
        • 157
        • germany
        The same problem with both batteries, and I have to remove the battery. The laptop turns on without the battery. Then I have to put the battery in the laptop to charge it. Otherwise, it won't work.
        • mon2
          • Dec 2019
          • 14025
          Locate the charger IC on the board and share the topside markings. We can then locate a reference diagram or datasheet for this charger IC to study what should be similar to your logic board. Often, the charger IC is from BQ = Texas Instruments. If not sure, just take a few pics of all square (QFN) packaged IC on your board. The charger IC should be nearby the DC in connector and also close to the battery connector.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            U mean you connect charger first and then battery and it charges fine? And if battery is put first and then charger,it dont charge? Right?
            If so, fault lies in dc-in mosfets and/or discharge mosfet.
            • samtron786
              • Aug 2016
              • 157
              • germany
              EMB24B03G PQ1
              EMB20P03V PQ2
              • samtron786
                • Aug 2016
                • 157
                • germany
                Do you mean if you connect the charger first and then the battery, it charges perfectly? That's exactly how it works.
                And if you connect the battery first and then the charger, it doesn't charge? Is that true? Yes, that's true.​
                • mon2
                  • Dec 2019
                  • 14025
                  Remove all power. Meter in resistance mode. Not diode mode.
                  Measure the resistance across the mosfet:
                  source & drain
                  source & gate
                  gate & drain
                  each measurement must be hundreds of k ohms or higher else is a suspect.
                  • samtron786
                    • Aug 2016
                    • 157
                    • germany
                    S1
                    Source & Drain
                    .291 MG
                    Source & Gate 99,7 Kohm
                    Gate & Drain .392 MG
                    S2
                    Source & Drain, 00,4 Ohm
                    Source & Gate, 37,2 Ohm 50,0 Ohm
                    Gate & Drain. 36,2 Ohm
                    • mon2
                      • Dec 2019
                      • 14025
                      They both look bad but S2 is definitely shorted. Flux and remove the S2 mosfet and test the same when the part is on your work table. When S2 is removed, test the resistance again on S1. If the measurements remain to be similar, also replace S1 mosfet.
                      • samtron786
                        • Aug 2016
                        • 157
                        • germany
                        I have two more pieces here exactly the same
                        S1
                        Source & Drain, 64,2 Kohm
                        Source & Gate, 36,0 Ohm
                        Gate & Drain. 60,0kohm
                        S2
                        Source & Drain, 01,4 Ohm
                        Source & Gate, 36,5 Ohm
                        Gate & Drain. 38,5 Ohm
                        S1
                        Source & Drain, .2,36 K Ohm
                        Source & Gate, O.L
                        Gate & Drain. O.L.
                        S2
                        Source & Gate, 30,3 Ohm
                        Gate & Drain. .350 MG 30,3 Ohm
                        • samtron786
                          • Aug 2016
                          • 157
                          • germany
                          I only wrote to you about one. EMB24B03G
                          Dual P‐Channel Logic Level Enhancement Mode Field Effect Transistor
                          I'm now writing to you about a P-Channel Logic Level Enhancement Mode Field Effect Transistor.
                          EMB20P03V
                          B20 P03​
                          Source & Drain, 66,4 K ohm
                          Source & Gate, 19,7 K Ohm
                          Gate & Drain. .570MG
                          • mon2
                            • Dec 2019
                            • 14025
                            Each of the posted S2 mosfets look to be defective. Flux and remove them and then test their resistance when they are no longer soldered to the board.
                            Very likely, the resistance readings will be similar and the parts are indeed defective. Proceed to test the S1 parts after S2 is removed. Perhaps S2 is influencing the low readings on S1. If S1 readings are still low, replace them as well.
                            The same test method can be used to diagnose other mosfets linked to the charger IC.
                            • samtron786
                              • Aug 2016
                              • 157
                              • germany
                              OK, I'll do that right away. If they're defective, can you please suggest which ones I should buy and order?
                              Thank you.​
                              • mon2
                                • Dec 2019
                                • 14025
                                Can you confirm that for the DUAL P-channel mosfet, you have indeed measured the resistance across each leg as requested?
                                The posted S1 and S2 measurements are for this single device?
                                Internal view of the dual mosfet:
                                The PQ2 mosfet is a single P-channel mosfet which is also low in resistance.
                                Are you ok to purchase from Digikey? It will be faster to receive goods from Digikey or Mouser than Aliexpress. If you not in a rush, Aliexpress will be cheaper.
                                • samtron786
                                  • Aug 2016
                                  • 157
                                  • germany
                                  Do I need to look for the same MOSFET, or can you recommend one?
                                  Thanks​
                                  • mon2
                                    • Dec 2019
                                    • 14025
                                    No, you can replace with a suitable or perhaps even better rated parts for each mosfet on the board. Are you in a rush? If yes, Digikey or Mouser may make more sense. Even faster if you have access to a donor board for at least testing out the repair process of one board. If you are ok to wait, consider Aliexpress.
                                    Can you share the details from post # 16? Wish to be sure we are indexing the same parts. The measurements are very low so you have a defective mosfet.
                                    • piernov
                                      Laptop battery charging circuit
                                      by piernov
                                      1. Some theory
                                      1.1. Introduction
                                      Almost every laptop has a charging circuit of some sort, that does a few things:
                                      • Manages switching between AC adapter and battery power
                                      • Manages battery charging and generates power rail to charge battery
                                      There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                      • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                      • Narrow VDC (NVDC)
                                      Texas instrument has a nice overview of these technologies with some more details at https:...
                                      11-15-2020, 01:31 PM
                                    • Iherduleikgemz
                                      Asus FX505DY - Battery not charging - BQ24780S
                                      by Iherduleikgemz
                                      Hello everyone
                                      I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                      I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                      01-13-2025, 03:54 PM
                                    • johnbeton
                                      Asus X415EA not charging battery
                                      by johnbeton
                                      I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                                      So far I measured all the pins on the bq24780s controller with the following result:
                                      1. ACN = 0.0V
                                      2. ACP = 19.02V
                                      3. CMSRC = 18.5V
                                      4. ACDRV = 23.9V
                                      5. ACOK = 5.9V
                                      6. ACDET = 2.57V
                                      7. IADP = 0.17V
                                      8. IDCHG = 0V
                                      9. PMON = ?
                                      10. PROCHOT = 5.05V
                                      11. SDA = 3.3V
                                      12. SCL = 3.3V
                                      13. CMPIN = 0.47V
                                      14. CMPOUT = 6.0V
                                      15. BATPRES = 0.0V
                                      16....
                                      05-19-2025, 04:05 AM
                                    • Shinju
                                      Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                      by Shinju
                                      Hey All!
                                      Long time forum member here with a problematic laptop issue!
                                      I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                      The laptop would not power on with the new battery installed without the power supply being plugged in.
                                      When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                      TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                      10-20-2021, 04:58 PM
                                    • drlarsen
                                      MacBook Air M1 A2337 battery/charging issue
                                      by drlarsen
                                      Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                      I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                      On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                      After some hours, the battery status did not improve. Restore via DFU did not help.
                                      I connected the power adapter to a Kill-a-Watt...
                                      07-17-2025, 02:35 PM
