MACBOOK PRO A2338, ERROR 4014 IN AC2
  • Universo Apple
    • May 2025
    • LIMS
    HELLO EVERYONE, I HAVE A MACBOOK PRO A2338, WHICH TURNED OFF OUT OF NOWHERE, THE USB TEST GENERATES 20 VOLTS BUT AFTER A WHILE IT RESTARTS... I TRIED TO RESTORE BUT I GOT ERROR 4014... ANY IDEAS?
  • sdogs
    macbook pro M1 a2338 no video on internal display PP3V3_S2 short
    by sdogs
    Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
    First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
    I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
    06-27-2025, 01:58 PM
  • sdogs
    by sdogs
    06-27-2025, 11:26 AM
  • classicandy
    MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
    by classicandy
    Hi Everyone,
    Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
    UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
    04-14-2024, 12:00 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    The TV does not turn on, the standby indicator is on. All voltages are present.
    Emms is dead. Not readable, not detected.
    Replaced emmc.
    But with another dump there is no launch
    Terminal log
    UART
    AC_ON
    RPMB key is not yet programmed
    HASH1_VERSION=0x00000000 64bit
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0...
    06-01-2025, 02:11 AM
  • dbuergi
    Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
    by dbuergi
    this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
    Is there anything i can do?
    11-19-2024, 09:27 AM
