MACBOOK PRO A2338, ERROR 4014 IN AC2
+ More Options
Posts
  • Universo Apple
    • May 2025
    • LIMS
    HELLO EVERYONE, I HAVE A MACBOOK PRO A2338, WHICH TURNED OFF OUT OF NOWHERE, THE USB TEST GENERATES 20 VOLTS BUT AFTER A WHILE IT RESTARTS... I TRIED TO RESTORE BUT I GOT ERROR 4014... ANY IDEAS?
  • sdogs
    macbook pro M1 a2338 no video on internal display PP3V3_S2 short
    by sdogs
    Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
    First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
    I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
    06-27-2025, 01:58 PM
  • sdogs
    by sdogs
    06-27-2025, 11:26 AM
  • classicandy
    MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
    by classicandy
    Hi Everyone,
    Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
    UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
    04-14-2024, 12:00 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • dbuergi
    Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
    by dbuergi
    this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
    Is there anything i can do?
    11-19-2024, 09:27 AM
