ASUS X509FAC no power to board
  • someonenotyou
    • Feb 2021
    • 55
    • LV
    Hi.
    I have an ASUS X509FAC with no power going to the board.
    19V gets from DC Jack to PQ8901 and PC8915 but not further (PC8915 should switch on the PQ8901, correct?)
    But, after PQ8902 I get 3.2V on AC_BAT_SYS.
    I am at loss, as I cannot find any shorts and don`t know where else to look.
    Any suggestions, please?
    Thank you.
    Hi, I need asus x415 (x509fac motherboard) schematic or boardview pls
  • Sephir0th
    • Oct 2020
    • 1282
    Typical reasons are a failed charging controller or missing ACDET caused by a failed DC-IN Jack.
    Do you have clear pictures of the whole board for us, front and back?
    FairRepair on YouTube
    • someonenotyou
      • Feb 2021
      • 55
      • LV
      On PR8904 (RES 127K OHM 1/16W (0402) 1%//TA-I/RM04FTN1273) I measured this:
      Pin 1 A/D_DOCK_IN - 19.77V
      Pin 2 P_CHG_ACDET_10 - 0.671V
      Here are pictures. The best I could make:
      • Sephir0th
        • Oct 2020
        • 1282
        AC_BAT_SYS is NOT shorted to GND, yes? Confirm please.
        If not, we need a close up of this area here.
        • Sephir0th
          • Oct 2020
          • 1282
          And a close-up of the DC-IN Jack too please
          • someonenotyou
            • Feb 2021
            • 55
            • LV
            AC_BAT_SYS to GND has a resistance of 5.5MOhm.
            Here are the requested pictures. If you need anything else, please ask.
            The middle pin feels solid in the DC Jack.
            • Sephir0th
              • Oct 2020
              • 1282
              This pin is supposed to grounded as soon as the charger is plugged. With and without power. Check whether it is like that. If not, the port is the origin of the issue and we need to find a workaround.
              • someonenotyou
                • Feb 2021
                • 55
                • LV
                Thank you so much.
                Yes, it was the DC Jack, and the pin did not get grounded. The pin supposed to touch the barrel of the charger, was too straight and dirty.
                Also, the correct pin was under the circled one. P_A/D_IN_DETECT
                Click image for larger version  Name:	p_ad_in_detect.png Views:	0 Size:	64.8 KB ID:	3654713
                So, I desoldered the DC Jack, disassembled it, curved and cleaned the pin, so there is a good contact now.
                Click image for larger version  Name:	photo_2025-06-08_12-13-22.jpg Views:	0 Size:	121.7 KB ID:	3654715 Click image for larger version  Name:	photo_2025-06-08_12-13-26.jpg Views:	0 Size:	121.0 KB ID:	3654717 Click image for larger version  Name:	photo_2025-06-08_12-13-30.jpg Views:	0 Size:	112.1 KB ID:	3654716
                Again, thank you. Did not think to check for a detect pin on the DC Jack, as I had 19V coming out of it.
                • Sephir0th
                  • Oct 2020
                  • 1282
                  Another possibility would have been to simply short the charger detect line with GND permanently, with a wire for example.
                  Well done and you're welcome.
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • DynaxSC
                    ASUS STRIX Z490-F GAMING - No POST, stubborn board
                    by DynaxSC
                    I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                    The situation looks like this:
                    After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                    1. RTC oscillates normally (32.768KHz).
                    07-08-2022, 05:45 AM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • ShadowAi12
                    ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                    by ShadowAi12
                    I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                    • The board enters a "ready to power on" state after plugging in the PSU.
                    • Pressing the power button increases power draw.
                    • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                    Measurements:
                    (taken after pressing the power button, while the board is attempting to start)
                    • H_SKTOOC#
                    06-11-2025, 01:05 PM
