Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
  • hopkok
    • Oct 2014
    • 179
    • Slovakia
    Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
    3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
    I checked for low resistance on coils, no low resistance.
    Anyone with same issue like me?
    Thanks for any help.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    SUSP_N aka SUSP# missing is the most common fault on this mb. has faced same issue multiple times.
    Its RYZEN APU which needs reballing. To test just heatup near ryzen for 30-45 seconds(not on top of it) and very likely you will get display.
    • hopkok
      • Oct 2014
      • 179
      • Slovakia
      Thanks for hint...will try. How about that horrible black epoxy around CPU, is there any good way to lift CPU without pads?
      • hopkok
        • Oct 2014
        • 179
        • Slovakia
        Hi, I reheated APU, but no change. Can this by KBC issue as well?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Very very unlikely to be a KBC issue. Its very difficult to de solder this apu 'coz of black glue.
          Some pcb pads will definitely torn off(specially the side you tried to lift it). however, they are very likely not connected pads.
          I still bet for a defective/dry ryzen
          • hopkok
            • Oct 2014
            • 179
            • Slovakia
            You are right, all 3 boards dead CPU...
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Have faced the same issue atlest 10 times on this very board. however, 5 or 6 were fixed.Rest to garbage bin.
              • master3112
                • Mar 2024
                • 87
                • Slovakia
                Hello friends, can anyone help me?
                I have a Lenovo Legion 5 Pro 16ACH6H, Board: NM-D562 REV.3
                problem is that there is no +3VALW on the PL6201 and also +0.75VALW on the PL7701. The +3VALW is provided by the PU6201 using PQ6201 and PQ6202. The +0.75VALW may not be present because +3VALW is not present.
                The PU6201 is responsible for:
                - +3VALW
                - +5VALW
                - +3VLP
                - +5VLP
                All but +3VALW are available. The output for +3VALW is activated on pin 6 of the PU6201 from EC. I have 0V here. I have measured the +3VALW rail and found no abnormalities. When I feed the +3VALW rail with 3V3 from the external power supply, I have a consumption of 0.1A. No short circuit or anything. I have tried
                - Disconnected the PJ6206 for the +3VALW.
                - Already replaced the EC.
                Does anyone have an idea why the EC does not enable the +3VALW and +0.75VALW?
                THX
                • hopkok
                  • Oct 2014
                  • 179
                  • Slovakia
                  Change PU6201, if not help, PCH in CPU mostly dead, very common...
                  • master3112
                    • Mar 2024
                    • 87
                    • Slovakia
                    THX hopkok
                    I have already replaced the PU6201. There is no enable signal on PU6201 pin6, nor on PU7701 pin11 for +0.75VALW. The EC must somehow know that something is wrong with the PCH and therefore does not activate +3VALW. Which pins does the EC use to get feedback from the PCH and can it be measured by the resistance? I also have the same healthy board here and could compare it. Do you have any experience?
                    • hopkok
                      • Oct 2014
                      • 179
                      • Slovakia
                      Check SUSP_N, if not pressented and I think it will not, BAD CPU. Check schematic for SUSP_N. You can try reheat CPU if any change.
                      • Stevedb
                        Stevedb
                        • Feb 2018
                        • 624
                        • Belgium
                        Did you also try holding pressure sometimes heating doesn't help but what mcplslg says the ryzen apu needs to be reballed this is pain in ass because there is glue underneath. It known issue
                        • master3112
                          • Mar 2024
                          • 87
                          • Slovakia
                          The signal is only present on the healthy mainboard when the power button is pressed. It is an output signal from the EC. But is this the reason why the +3VALW is not activated? If I remove the CPU from another board, all voltages are present. So if the PCH should have no contact, I understand that the board does not start. I would be interested to know what is bothering the EC that it is not activating the +3VALW. Does it recognize a wrong resistor or something?
                          • master3112
                            • Mar 2024
                            • 87
                            • Slovakia
                            Was the +3VALW not present on one of your defective mainboards where the CPU was defective?
                            • hopkok
                              • Oct 2014
                              • 179
                              • Slovakia
                              Not sure...
                              • PontyPCs
                                • May 2016
                                • 16
                                • United Kingdom
                                Any chance i can get the schematic for this board, i have the same issue, Power light but no other function
                              • Docus
                                Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                by Docus
                                Hi everyone 😀,
                                I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                1. I already own the exact same model, but its plastic chassis is badly damaged.
                                06-10-2025, 04:24 PM
                                Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-07-2024, 05:00 AM
                              • ugamazing
                                by ugamazing
                                12-17-2024, 07:05 PM
                                LENOVO Legion Y720 Legion 1800x Specification for Upgrade or Repair
                                This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                09-12-2024, 02:30 PM
