I am trying to identify the burnt component on DA0zdgmb8d0.
identification of a component on DA0zdgmb8d0
by nobbnobb1I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
- 1x 3.14 A @ 250V main circuit fuse
- 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
- 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....-
by dicky96Hi guys
This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
The good phase... -
by mohammedsaidHp Probook 650 G2 identification of the burnt component
Q60010 not found
D6035
Motherboard CIRCUS 6050A2723701-MB-A02... -
by RcolombiniHello everyone,
I need help identifying a burned IC on the main logic board (MLB) of an Amazon Echo Show 15. The board number is 30-006507 REV01.
Device failure history:
The device started rebooting every 2 minutes. I assumed it was a power supply issue and replaced it. After connecting the new power supply, the privacy button LED started blinking red with no display output, and I immediately noticed a strong burning smell. I powered it off immediately and opened the device.
Component details:
∙ Marking: AFVP (first line) / 672 (second line)
∙ Pin 1 indicator:...2 Photos -
by w00pzI have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
Hope someone will be able to identify the component.
Many thanks for your help!
Edit: High-res picture added on a normal board (not mine)...2 Photos - Loading...
