Asus X415EA not charging battery
  • johnbeton
    • Jun 2021
    • 95
    • Belgium
    I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
    So far I measured all the pins on the bq24780s controller with the following result:
    1. ACN = 0.0V
    2. ACP = 19.02V
    3. CMSRC = 18.5V
    4. ACDRV = 23.9V
    5. ACOK = 5.9V
    6. ACDET = 2.57V
    7. IADP = 0.17V
    8. IDCHG = 0V
    9. PMON = ?
    10. PROCHOT = 5.05V
    11. SDA = 3.3V
    12. SCL = 3.3V
    13. CMPIN = 0.47V
    14. CMPOUT = 6.0V
    15. BATPRES = 0.0V
    16. TB_STAT = 3.38V
    17. BATSRC = 0.9V (after +/- 25 seconds = 0.23V)
    18. BATDRV = 0.93V (after +/- 25 seconds = 0.27V)
    19. SRN = 0.9V (after +/- 25 seconds = 0.23V)
    20. SRP = 0.9V (after +/- 25 seconds = 0.23V)
    21. ILIM = 1.16V
    22. GND
    23. LODRV = 0.0V
    24. REGN = 6.0V
    25. BTST = 5.87V
    26. HIDRV = 0.9V (after +/- 25 seconds = 0.23V)
    27. PHASE = 0.9V (after +/- 25 seconds = 0.23V)
    28. VCC = 18.74V​
    The highside and lowside mosfet don't seem to be shorted or defective.
    I also tried another battery with no result
    If someone has an idea what I can check, I would appreciate all the help, still learning on these charging circuits.
  • mon2
    • Dec 2019
    • 14161
    Pins 1 & 2 should be the same voltage. Pin 1 pcb trace (ACN) is broken. Fix it to fix the issue.
    • johnbeton
      • Jun 2021
      • 95
      • Belgium
      i'm sorry, I checked again, and PIN1 is also 19.02V, i must have made an error in my first measurement.
      • mon2
        • Dec 2019
        • 14161
        Ok.
        2. ACP = 19.02V
        3. CMSRC = 18.5V
        CMSRC is a measurement between the 2 x DCin mosfets so the voltage here should be equal to the voltage @ ACP/ACN junctions.
        Confirm the resistance of the series resistor that will be on the CMSRC pin and mates with the DCin mosfets. Check the datasheet for this charger IC to compare notes on what Asus has most likely used for this logic board.
        • DeXXter
          • Aug 2023
          • 91
          • Chile
          Did u check the first mosfets? A failure there can trigger charging issues too. Is your ec fine? no water there?
          • johnbeton
            • Jun 2021
            • 95
            • Belgium
            The resistor is 4.02KOhms, I have 19V on pin 1 and 18.55V on pin 2
            I checked the first mosfets for short, but they are not short. There was no water in the area of the EC.
            • mon2
              • Dec 2019
              • 14161
              Remove all power. Measure the resistance between pins 1 & 2 - directly at the charger IC.
              Repeat for the SRN / SRP pins. What are the measurements in ohms? Comparing to the schematic values. Need to confirm the full path resistance for the current sense loop circuit is within specs.
              • m1ch43lzm
                • Mar 2019
                • 410
                • Peru
                Hi, I would check the traces going to the following pins
                From the BQ24780S datasheet:
                BATSRC, 17
                Connect to the source of N-channel BATFET. BATDRV voltage is 6 V above BATSRC to turn on BATFET.
                BATDRV, 18
                Charge pump output to drive N-channel MOSFET between battery and system (BATFET). BATDRV voltage is 6 Vabove BATSRC to turn on BATFET and power system from battery. BATDRV is shorted to BATSRC to turn off BATFET. Place a 4-kΩ resistor from BATDRV to the gate of BATFET limits the inrush current on BATDRV pin.
                SRN, 19
                Charge current sense resistor negative input. SRN pin is for battery voltage sensing as well. Connect SRN pin with a 0.1-µF ceramic capacitor to GND for common-mode filtering. Connect a 0.1-µF ceramic capacitor from SRP to SRN to provide differential mode filtering.
                SRP, 20
                Charge current sense resistor positive input. Connect a 0.1-µF ceramic capacitor from SRP to SRN to provide differential mode filtering.
                LODRV, 23
                Low-side power MOSFET driver output. Connect to low-side N-channel MOSFET gate
                HIDRV, 26
                High-side power MOSFET driver output. Connect to the high side N-channel MOSFET gate.
                PHASE, 27
                High-side power MOSFET driver source. Connect to the source of the high-side N-channel MOSFET.
                You should get battery voltage at pin 17, check the 10ohm resistor and the trace going to it from pin 17
                Pins 19,20, same, around battery voltage, through 2 10ohm resistors, check resistors and traces
                Measure resistance between pins 19 and 20, you should get 20ohms
                Pin 27, you should get battery voltage
                Schematics/boardview
                https://www.badcaps.net/forum/troubl...c-or-boardview
                I'm looking at the X421 schematics posted there
                SN2867 = BQ24780S
                • johnbeton
                  • Jun 2021
                  • 95
                  • Belgium
                  Resistance between pin 1 & 2 on charger IC = 1.1 Ohm
                  Resistance between SRN & SRP on charger IC = 21.2 Ohm
                  PR8968 = 10.4Ohm
                  Thanks for the link to boardview
                  • m1ch43lzm
                    • Mar 2019
                    • 410
                    • Peru
                    Measure voltage at the current sense resistor PRS8903 with the battery plugged in, you should get the battery voltage
                    If not, remove all power, measure continuity from the + on the battery connector on the board to PRS8903, also check PJP8901 if available on your board (can't check board view right now, I'm on my phone), should be closed with a solder blob
                    • johnbeton
                      • Jun 2021
                      • 95
                      • Belgium
                      Both batteries are completely empty.
                      The resistance from the + pin to PRS8903 is 1.1 Ohm on one side, 11.1 Ohm on the other side.
                      PJP8901 is present and is indeed a solder blob.
                      Edit: one thing I noticed on PD8900 I have 19V on Pin 2 and 3, and 2.9V on Pin 1. Don't know if this is normal ?
                      • alfredposadas08
                        • Dec 2020
                        • 3
                        • PHILIPPINES
                        make sure the dc in mosfets are fully switched
                        • johnbeton
                          • Jun 2021
                          • 95
                          • Belgium
                          I checked them on shorts, but no shorts, and have 19V past botch mosfets, is this ok ?
                          • mon2
                            • Dec 2019
                            • 14161
                            Need the actual mosfet resistance measurements of the high side and low side battery mosfets.
                            Source / drain
                            source / gate
                            Gate / drain
                            Post each measurement in ohms.
                            • johnbeton
                              • Jun 2021
                              • 95
                              • Belgium
                              Highside
                              Source / drain (black probe on drain) = starts at 2.89 MOhm and going up while I measure
                              Source / drain (red probe on drain) = 0.00 Ohm
                              source / gate = 9.9 KOhm
                              Gate / drain = 1.4 MOhm and going up while I measure
                              Lowside
                              Source / drain = 4.9 MOhm
                              source / gate = 0.21 MOhm
                              Gate / drain = 1.8 MOhm and going up while I measure​
                              • mon2
                                • Dec 2019
                                • 14161
                                High side mosfet is defective. Must be replaced. Suggest to also replace lowside mosfet for safety.​
                                • johnbeton
                                  • Jun 2021
                                  • 95
                                  • Belgium
                                  I removed the mosfets and checked them off the board, they seem to be fine, but just to be sure, I replaced them with equivalent mosfets, but the problem remains.
                                  Maybe the controller itself is bad ? I have a donor board with the same controller, I could try exchange the controller.
                                  • mon2
                                    • Dec 2019
                                    • 14161
                                    How fine are they? Need the actual measurements.
                                    • johnbeton
                                      • Jun 2021
                                      • 95
                                      • Belgium
                                      With black probe on drain and red probe on source I have 9,89 KOhm on 1 mosfet, and 11,73 KOhm on the other mosfet.
                                      All other combinations (reverse probes, source - gate, drain - gate, ....) are OL.
                                      I also tested in diode mode:
                                      Black probe on drain, red probe on gate. Then black on drain, red on source gives 0 Ohm.
                                      Put black probe on gate, closes the mosfet.
                                      • johnbeton
                                        • Jun 2021
                                        • 95
                                        • Belgium
                                        I replaced the charging controller, but the problem remains, I also ordered yet another battery, because the other 2 stay a 0 volt.
                                        The new battery came in and had 7.56V, according to the system the battery is charged for 53%.
                                        With the charger plugged in, the charging led goes orange, as if it is charging, but the battery percentage stays steady, the voltage on the battery connector goes up very slow.
                                        With the charger unplugged the battery drains like normal.
                                          ASUS X415EA-EB196TS Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS X415EA-EB196TS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X415EA-EB196TS boardview and X415EA-EB196TS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 12:10 AM
                                        • mferna14
                                          ASUS X415EA battery not charging
                                          by mferna14
                                          Dear friends., working on this ASUS R565EA-UH51T. motherboard part # is X415EA R:6.0. The schematic which is uploaded on Badcaps is not the correct one. Can't figure out the traces. The battery does not charge at all. Firstly it was not turning on. With my experience, I correctly bypassed the 2 initial MOSFET & now the laptop turns on perfectly but does not charge the battery. Upon diagnostics I found that on both MOSFET (N-Channel) GATES volts are missing. Out here it should be nealry 24v to turn on the MOSFET GATEs & then the Laptop would turn on. This missing volts are generating from...
                                          Yesterday, 04:42 PM
                                        • Kailash B. Poudel
                                          BIOS REQUEST: Asus A1500E ,X415EA MAIN BOARD REV 7.0
                                          by Kailash B. Poudel
                                          BIOS REQUEST:
                                          ASUS X415EA MAIN BOARD REV 7.0
                                          A1500E-ABQ2481WS
                                          SN: N5NOCV13R797218...
                                          02-25-2025, 12:39 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • thomasmagic
                                          not charging asus g531gw 1.6
                                          by thomasmagic
                                          hello,
                                          if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
                                          i have found short on C3907 (PVDD_AMP) and remove it
                                          Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
                                          It's not 1st time when i remove short after the battery is not detect
                                          On mybook i know we can make jumper beetween two lines for recognised this one
                                          do you have solution for pc and actually this mainboard? Thanks for your help ...
                                          06-19-2025, 12:54 PM
