gigabyte nh50hpbm charges battery but doesn't power up
  • kjchatman
    • Dec 2012
    • 213
    • united states
    the sio has a slight glow to it under the thermal camera. pwr_btn stays high at 3.3v after pressing the power button. PCH_DPWROK doesn't go higher than 1.0v. ec_rsmrst stays at 0v
  • mon2
    • Dec 2019
    • 14662
    To save time, always link the schematic.
    The 'NH50HP' schematics are posted in the schematics forum.
    Locate and short the power button signal line to ground to emulate the power button.
    • kjchatman
      • Dec 2012
      • 213
      • united states
      pwr_btn stays high at 3.3v after pressing the power button. ec_rsmrst stays at 0v after pressing the power button
      • mon2
        • Dec 2019
        • 14662
        The power button is an active low signal. By default, the parked voltage on this line should be 3v3 when the power button is OPEN.
        When you press the button, the button should pull this line to 0v since the other side of the power button is mated to ground. Confirm it. After the button is released, the pull-up resistor will park the line once again to a value of 3v3.
        If you do not see this action, confirm the wiring to the power button line. As requested, use tweezers to short the pins on the connector block itself. See above and post back the test results.
        • kjchatman
          • Dec 2012
          • 213
          • united states
          i don't see b3j_sw1 on this board
          • kjchatman
            • Dec 2012
            • 213
            • united states
            pwr_btn goes to ground and then back to 3.3v
            • kjchatman
              • Dec 2012
              • 213
              • united states
              just flashed the bios and the EC and still no joy. Gave the board an ultrasonic bath also
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Mb not triggering at all can be for many reasons.
                Check RTC circuit/basic requirement of SIO like whether its powered or not,EC_RST#/LIDSW# etc.
                What's the resistance to GND on RSMRST#? Should be 10K or higher.
                • kjchatman
                  • Dec 2012
                  • 213
                  • united states
                  i think vcc_rtc is supposed to be 3.3v but it's 4.9 ohms to ground
                  • mon2
                    • Dec 2019
                    • 14662
                    Try the following. Carefully flux and remove:
                    R418 ; 0 ohm resistor - then test the resistance to ground again
                    If still shorted, continue..
                    C655 ; remove and test resistance to ground again
                    R294 ; remove and test resistance to ground again
                    Post your updates. Do not power up with out these parts. We are only hunting for the shorted component on this rail.
                    • kjchatman
                      • Dec 2012
                      • 213
                      • united states
                      i injected voltage before reading the last post. The resistance to ground instantly went back to normal and the computer is back in business. i had to put that the orignal bios and EC programming because it wasn't posting or detecting the battery
                      • mon2
                        • Dec 2019
                        • 14662
                        The injection process caused the shorted part to cry uncle and died. Probably was a shorted bad cap.
                        Hey! Good name for a website?
                        Respectively removing itself from the shorted rail. Either way, glad that it is fixed.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Sticking to basics solves more then 90% of repair cases as long as one has patience.
                          • DynaxSC
                            GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                            by DynaxSC
                            I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                            General test conditions:
                            - Tested with Core i5 6500 and Core I7 6700K - no difference
                            - Default BIOS settings, but tried also altering several memory setting - does not change anything
                            What is wrong:
                            With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                            When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                            03-21-2025, 06:23 PM
                            Thermal pad thickness for various laptop GPU / Graphics Cards
                            ASUS Dual RTX 2070 OC 8GB
                            ASUS ROG STRIX RTX 3080 OC
                            ASUS ROG STRIX RTX 3090
                            ASUS TUF Gaming RTX 3080 OC Edition
                            ASUS TUF GTX 1660 S-O6G GAMING
                            EVGA RTX 3060 Ti XC GAMING 8GB
                            EVGA RTX 3060 XC GAMING 12GB GDDR6
                            EVGA RTX 3080 FTW3 ULTRA GAMING
                            EVGA RTX 3080 TI FTW3 ULTRA GAMING
                            EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                            Gainward RTX 2080 Phoenix GS Specs
                            Gainward RTX 3070 Phoenix 8GB
                            Gainward RTX 3080 Ti Phoenix
                            GIGABYTE AORUS RTX 3080 MASTER 10G
                            02-09-2024, 08:08 AM
                            A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                            by momaka
                            More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                            And a shot of the label:...
                            01-26-2022, 03:26 AM
                          • nikovmiroslav
                            Gigabyte A5 X1 Need Bios
                            by nikovmiroslav
                            Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                            Gigabyte A5 X1
                            From motherboard:
                            S/N: 1TNH55ER1350895
                            P/N: 6-77-NH55ERQY-D02-2CGB
                            On sticker from the back of the laptop:
                            S/N: SN21351J000657...
                            08-24-2025, 09:15 AM
                            Gigabyte G series G5 MF-5 Notebook Specification for Upgrade or Repair
                            This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                            09-07-2024, 07:19 AM
