the sio has a slight glow to it under the thermal camera. pwr_btn stays high at 3.3v after pressing the power button. PCH_DPWROK doesn't go higher than 1.0v. ec_rsmrst stays at 0v
gigabyte nh50hpbm charges battery but doesn't power up
When you press the button, the button should pull this line to 0v since the other side of the power button is mated to ground. Confirm it. After the button is released, the pull-up resistor will park the line once again to a value of 3v3.
If you do not see this action, confirm the wiring to the power button line. As requested, use tweezers to short the pins on the connector block itself. See above and post back the test results.Comment
Mb not triggering at all can be for many reasons.
Check RTC circuit/basic requirement of SIO like whether its powered or not,EC_RST#/LIDSW# etc.
What's the resistance to GND on RSMRST#? Should be 10K or higher.Comment
Try the following. Carefully flux and remove:
R418 ; 0 ohm resistor - then test the resistance to ground again
If still shorted, continue..
C655 ; remove and test resistance to ground again
R294 ; remove and test resistance to ground again
Post your updates. Do not power up with out these parts. We are only hunting for the shorted component on this rail.Comment
i injected voltage before reading the last post. The resistance to ground instantly went back to normal and the computer is back in business. i had to put that the orignal bios and EC programming because it wasn't posting or detecting the batteryComment
by DynaxSCHi,
I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
General test conditions:
- Tested with Core i5 6500 and Core I7 6700K - no difference
- Default BIOS settings, but tried also altering several memory setting - does not change anything
What is wrong:
With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2... -
Thermal pad thickness for various laptop GPU / Graphics Cards
ASUS Dual RTX 2070 OC 8GB
ASUS ROG STRIX RTX 3080 OC
ASUS ROG STRIX RTX 3090
ASUS TUF Gaming RTX 3080 OC Edition
ASUS TUF GTX 1660 S-O6G GAMING
EVGA RTX 3060 Ti XC GAMING 8GB
EVGA RTX 3060 XC GAMING 12GB GDDR6
EVGA RTX 3080 FTW3 ULTRA GAMING
EVGA RTX 3080 TI FTW3 ULTRA GAMING
EVGA RTX 3090 XC3 ULTRA GAMING 24GB
Gainward RTX 2080 Phoenix GS Specs
Gainward RTX 3070 Phoenix 8GB
Gainward RTX 3080 Ti Phoenix
GIGABYTE AORUS RTX 3080 MASTER 10G
Channel: Schematics and Boardviews
02-09-2024, 08:08 AM -
by momakaMore eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
And a shot of the label:... -
This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...09-07-2024, 07:19 AM
This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...09-07-2024, 07:19 AM
- Loading...
