MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
  • im_trying
    • May 2025
    • 14
    • Italy
    Hi, thanks for helping.
    The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
    For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
    I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
    The photo below shows this better than words.
    Thanks for anyone that helps!
  • mon2
    • Dec 2019
    • 14169
    Is your meter a manual scale type or automatic for selecting the resistance? The ‘1’ may indicate that the meter scale is too low so switch to a higher resistance scale till you have a proper measurement.
    • im_trying
      • May 2025
      • 14
      • Italy
      Automatic scale, but it measures in ohms. I wrote the ohm in the picture, it's around 6 to 3 Ohms. Which seems pretty low to me for a DC-IN. Right?
      • mon2
        • Dec 2019
        • 14169
        Yes, very low. Flux and carefully remove the brown ceramic capacitor showing in your pic as shorted. Then measure the resistance again without power to the board.
        • im_trying
          • May 2025
          • 14
          • Italy
          Done. Capacitor is good, no short on him. The short is still present, 0 ohm on the south pad and 4 ohms on the north one.
          • mon2
            • Dec 2019
            • 14169
            Which charger IC is onboard? Share the topside smd markings. We may be able to learn about your board through reference datasheets on the internet. Any other silk screen markings on this logic board? Perhaps a schematic is available.
            There is a concern about the 2nd DCin mosfet which is often leading to the main power rail. That is, the main power rail may be shorted due to CPU / PCH damage.
            The highlighted pins on the left mosfet are the source pins (1-2-3). You are measuring this cluster to ground and are with ~6 ohms?
            Remove all power. Meter in resistance mode.
            Measure the resistance across these mosfets:
            source (1-2-3) & drain (5-6-7-8)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            Each measurement should be hundreds of k ohms or higher else is a suspect. Post each measurement. If you have a low resistance to ground of the source / drain pins, then the load side of the mosfet is shunted.
            • im_trying
              • May 2025
              • 14
              • Italy
              So, I just found a schematic for the board. It's here on badcaps so I'll just link the post: https://www.badcaps.net/filedata/fetch?id=3486425
              Just to be sure that it wasn't the BQ chip, I desoldered and measured, no luck. The short is still there. BQ chip has been resoldered on.
              Measurements:
              Source to drain: 450kOhms
              Source to gate: 240kOhms
              Drain to gate: 700kOhms
              • mon2
                • Dec 2019
                • 14169
                Locate the VCORE caps as attached. Yellow tips of the parts are the VCORE rail.
                Measure the resistance from the source (1-2-3) mosfet pins you are referencing to these caps. What is the resistance? We are checking if there is a high side mosfet leak of the vcore power rail.
                • im_trying
                  • May 2025
                  • 14
                  • Italy
                  Done. From the source of the second dc-in mosfet to the highlighted caps in yellow it's the same 6 Ohms. The same caps relative to ground are 2.5 Ohms.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    PR344 should be desoldered and then you need to inject 1V/5A on the shorted side from dc supply and wait for 10 mins to see if anything getting warm.
                    Put black probe on the shorted side of PR344 and touch red probe on every coil on the board(meter in diode mode).The one which shows same value as the shorted side on PR344, is likely the culprit.
                    • Lee M.
                      IR night vision goggles to find shorted panel line?
                      by Lee M.
                      Has anybody tried to use IR night vision goggles or other thermal imaging device to find a shorted line in a ribbon cable going from a panel driver board into the panel? I would think the shorted line would get hotter than the other lines and might just show up on a thermal imaging device. Just wondering if anyone has tried this and if so did it work?
                      11-10-2023, 03:19 PM
                      MSI Gaming GF65 10UE-213US Thin Notebook GF Specification for Upgrade or Repair
                      This specification for the MSI Gaming GF65 10UE-213US Thin Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF65 10UE-213US Thin boardview and GF65 10UE-213US Thin schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 05:50 AM
                      MSI Gaming GF65 10UE-284FR Thin Notebook GF Specification for Upgrade or Repair
                      This specification for the MSI Gaming GF65 10UE-284FR Thin Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF65 10UE-284FR Thin boardview and GF65 10UE-284FR Thin schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 03:40 AM
                      MSI Gaming GF65 10UE-200XCZ Thin Notebook GF Specification for Upgrade or Repair
                      This specification for the MSI Gaming GF65 10UE-200XCZ Thin Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF65 10UE-200XCZ Thin boardview and GF65 10UE-200XCZ Thin schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 03:10 AM
                      MSI Gaming GF65 10UE-098CZ Thin Notebook GF Specification for Upgrade or Repair
                      This specification for the MSI Gaming GF65 10UE-098CZ Thin Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF65 10UE-098CZ Thin boardview and GF65 10UE-098CZ Thin schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
