A1398 - 820-3663-A - not charging
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I got macbook pro A1398 15" from my friend. He told me that he changed battery and macbook stopped charging.
    Boardnumber : 820-3662-A
    I've checked and when i connect charger it's recognized by MacOS but there is no light on charger and it's not charging battery (i've tried multiple chargers still the same behaviour), i've also tried 3 different magsafe ports.
    I've check U7100 and replaced it multiple times (from other donor boards that i have) (i've tried probably 7 different U7100) - i've also checked current resistors around this ISL (R7151, R7152, R7121, R7122) they're all good.
    I was able to get one time led on charger but after maybe minute it turned off and stay so ...
    I've checked with thermal camera and i can see that U7100 is still getting warm (but i guess this is normal and this is chager IC)
    Also i noticed that C7105 - pin CHRG_DCIN is stable 20,3V when charger is connected but no light on charger.
    When i was checking with thermal camera around the board i noticed that one resistor (R5413) is getting warm but i've checked it and it have correct diode mode reading 0,74 pin 2 and OL on pin 1, also it's resistance is 33kOhms a it should be according to schematics.
    Any idea what this strange behaviour can cause ?
    Is it possible that U5000 is bad ?
  • reformatt
    • Feb 2020
    • 1488
    You are on the wrong track. If there is no light on the charger, then the SMC will not enable charging. You would start with the one wire circuit (U7000 and U7001). SMC_BC_ACOK comes from U7100 and this must be high to allow Vcc for U7000. SYS_ONEWIRE comes from the SMC and is used to communicate with the charger and establish it's wattage etc. SMC needs that info to determine whether charger is suitable or not, so lack of signal here means no charging. U7000 is an over voltage protection device so you should see identical signals on both input and output. If that all checks out, then you would look at the SMC itself.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      I've checked U7000 and U7001 (diode mode readings are ok)
      When power is connected U7000 and U7001:
      ADAPTER_SENSE - 2.8V
      SYS_ONEWIRE - 2.8V
      SMC_BC_ACOK_VCC - 3.4V
      SMC_BC_ACOK - 3.28V
      PP3V42_G3H - 3.42V
      Diode mode readings U7000 and U7001:
      ADAPTER_SENSE - 0.621
      SYS_ONEWIRE - 0.677
      SMC_BC_ACOK_VCC - 0.586
      SMC_BC_ACOK - 0.552
      PP3V42_G3H - 0.324
      • mon2
        • 14657
        Use ipa to clean the MagSafe contacts on the charger connector.
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          i tried cleaning, different connector, different charger... still no light
          • mon2
            • 14657
            Follow this flow chart:
            G3 to S3 State for Ivy Bridge Haswell and Broadwell - LogiWiki
            • obelix24
              • Jun 2023
              • 291
              • Slovakia
              according to this SYS_ONEWIRE should be 3.4V but i have only 2.8V
              PPBUS_G3H - 12.58V
              I'll try to replace U7000
              • mon2
                • 14657
                Wait..the voltage is low and is created by U7001.
                Measure the voltage to ground of pin 4 on U7001.
                Most likely, U7001 needs to be replaced.
                • obelix24
                  • Jun 2023
                  • 291
                  • Slovakia
                  pin 4 on U7001 -
                  SMC_BC_ACOK_VCC - 3.418V
                  i tried to replace U5000 and U7000 but now difference.
                  • obelix24
                    • Jun 2023
                    • 291
                    • Slovakia
                    i tried to replace U7001 but still the same .... the SYS_ONEWIRE is created by U5000 no ?
                    • mon2
                      • 14657
                      Remove all power. Measure the resistance across R7029. What is the value in ohms?
                      Yes, U5000 is the bus master for this communication channel but the Vcc voltage for U7000 is of concern. It is possible that you are measuring a lower than the peak voltage if the communication line is switching. That is, an oscilloscope will be the true test tool to use here. Another tool is a logic analyzer.
                      Replace U7000 if you have a known good one for testing.
                      • obelix24
                        • Jun 2023
                        • 291
                        • Slovakia
                        they all looks ok.
                        I noticed one this when i put everything back to case macbook doesn't turn on as before ....
                        I've returned original U5000 (the other one i've used from donor a1466 - same numbers) during replacing i probably damaged X29 as now macbook turns on but fans are on full speed.
                        Is this connected to Q6060 ?
                        But there is still no light on charger ... I was thinking if it's not caused but not original battery but i don't think as the light is not there even if battery is not connected and it should be there.
                        • obelix24
                          • Jun 2023
                          • 291
                          • Slovakia
                          is U5000 replecable on A1398 ? i tried from differrent 15" and macbook is not turning on and fans are going to max speed but not immediately but it take some time.
                          • obelix24
                            • Jun 2023
                            • 291
                            • Slovakia
                            I found that IC for temperature should be probably U5823
                            is it correct ? Is it most probably the cause of full fan ?
                            • obelix24
                              • Jun 2023
                              • 291
                              • Slovakia
                              After some digging i found out that left fan is faulty and have faulty ic on fan cable.
                              i'm still trying to find why there is no light on charger.
                              • obelix24
                                • Jun 2023
                                • 291
                                • Slovakia
                                ok so to me it looks like problem is with U5000 (but as i've tried to replace it and the macbook want start it looks like this U5000 is not replaceable ?)
                                • flat-earther
                                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                                  by flat-earther
                                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                  Windows also shows ''Plugged in'' when charger is not connected.
                                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                  If I let battery run out and say it has 3% Windows will...
                                  06-24-2025, 09:32 AM
                                • flat-earther
                                  how to prevent a connected charger from draining battery when not charging?
                                  by flat-earther
                                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                  So the battery is backfeeding the charger and being drained.
                                  How can I prevent...
                                  08-07-2025, 01:04 PM
                                • dimis1975
                                  Macbook A1466 2014 not charging with macsafe 2 charger
                                  by dimis1975
                                  I have a macboook air a1466 that stopped charging the battery.
                                  BAT PINS: with or without ADAPTER IN
                                  1- GND
                                  2- GND
                                  3- GND
                                  4-0V sense pin
                                  5-3.42V
                                  6-3.42V
                                  7- 8.4V
                                  8- 8.4V
                                  9- 8.4V
                                  AC Adapter plugged in: after a lot of of hours some times start charging
                                  No BAT Connected- Green to Orange
                                  AC Adapter plugged in: BAT Connected- no light
                                  The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                                  Any ideas what’s wrong please?...
                                  08-05-2025, 03:43 AM
                                • coasterghost
                                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                  by coasterghost
                                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                  System Hardware:
                                  Processor: AMD Ryzen 7 PRO 5850U
                                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                  09-08-2025, 10:46 PM
                                • pc_okay
                                  FX516PR not charging on DC charger (but charging on Type-C)
                                  by pc_okay
                                  Hello friends,
                                  I have this board not charging with charger, working fine on battery and type-C charger.
                                  Here what if found: my IC chip miss VCC so i follow the line P_CHG_VCC_30 (0V) to P_CHG_VCC_R_30 (0v) and i get 20V A/D_DOCK_IN.
                                  I loose my 20V on the PQ9009, i think it's dead because it's a P-Channel and I get 0V on gate and 20V on source and finally 0V on drain.
                                  Am I right?
                                  Links for shematics and boardview: https://www.badcaps.net/forum/troubl...aptops-tablets...
                                  10-02-2024, 06:16 AM
