sy8386brhc v sy8388brhc
  • adamski1952
    • Oct 2021
    • 94
    • england
    Hi all working on an Acer Aspire A515-57.The 3v LDO CHIP Sy8388brhc chip has shorted out. pu301 on the schematic here: https://www.badcaps.net/forum/troubl...c-or-boardview
    My question is can I replace (Sy8388brhc global part #SY21243B) which has High Efficiency Fast Response, 8A, 28V Input, with the sy8386brhc (global part# SY21138BRHC) wihch only supports 6A on the input side.
    Other than that they are identicle.
    was going to take pot luck but Ithout i'd run it by you guys first.
    Anyone have thoughts on this.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    If you are sure there is no difference between these two chips other then 8A/6A factor, you can replace it.
    • HackIdGaming
      • Jan 2019
      • 13
      • Jawa Barat
      sorry, does this work?
      • tony359
        Global AC logic output - XP Power FleXPower
        by tony359
        Hi all
        I've fixed a couple of FleXPower X7 power supplies. Since they have some logic outputs, I went to test them to make sure all was in order.
        "Fan Fail" would work when the fan is manually stopped.
        "Global DC" would change state when I manually adjusted one rail beyond 10%
        "Global AC" doesn't seem to do anything. To test, I power up the PSU and then I remove power. The 5VSB and Aux rails remain active for quite a few seconds after power is removed. I see the rails collapsing but there is no change in the "Global AC"...
        06-20-2025, 03:06 PM
      • husnu16
        Lenovo LOQ - LA-N221P Rev 1.0 Schematics or PU301 ic code?
        by husnu16
        Hello my precious masters;
        Lenovo LOQ - LA-N221P Rev 1.0 I need the code/model number of the PU301 integrated circuit on this mb. The integrated circuit is burnt and cannot be read. Can you help me with this?
        12-21-2024, 04:29 AM
        GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
        65 Watt Multiple Output Global Performance Switchers
        Condor Part Summary
        • 65 Watt Wide Range Input
        • High Efficiency (Up to 90%)
        • Universal input 90-264 Vac
        • 2-year warranty
        • Also available in single outputs
        • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
        • Exempt from line harmonics standard EN61000-3-2
        • Commercial Approved to UL1950, CSA-C22.2 No. 950,
        • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
        10-07-2024, 05:46 AM
      • trepachka
        Vostro 3510 LA-L246p missing 3.3V and 5V
        by trepachka
        This laptop (LA-L246p) came in with liquid damage in multiple spots. I had the board thorously cleaned. I found a shorted cap and a blown fuse in one location and now the laptop is charging. However, I am not getting 5V and 3.3V rails.
        This board is almost identical to LA-L243p or LA-L241p.
        PU501 (SY8288CRAC 5V converter) is getting ENLDO_3V5V (around 4.5V) on pin 11 but EN_5V (0V) on pin 12.
        Similarly,
        PU301 (SY8386BRHC 3.3V converter) is getting ENLDO_3V5V (around 4.5V) on pin 8 but EN_3V (0V) on pin 9
        So, obviosly the enable signal...
        10-01-2023, 10:55 PM
        GMT Global Mixed-Mode Technology marking codes pdf
        by SMDFlea
        Attached is a pdf containing most marking codes from the datasheets at the GMT website (as of 5th December 2021) ,including EOL
        and some obsolete parts.Also included are marking codes from some various datasheets not listed at the website.
        I`d appreciate your feedback if its useful to you.
        12-05-2021, 06:49 AM
