iPad Pro 11 3th no charge no power
  • Grandoni Manuel
    • May 2024
    • 12
    • San Marino
    Hello experts ! Have big problem and not understand with iPad Pro 11 3th gen.
    So with power supply work perfectly but if I connect usbc not power on !
    first under thermal can find a short near CD3217 on the 3v3 ACE line ! Take off it then stuck at 5v and 0 amps !
    then I try to change CD3217 with other one from MacBook but the iPad now shout down also the tool for see voltage and amps 😅
    ok then I want try to take one directly to donor working board and also the eprom for safety but stuck again 5v 0amps !!!!
    incredible 😳
    mom then I tried to change ACE circuit and also ORION but nothing!!!!! The situation always the same !!!!!
    someone can explain me where I wrong please ? 🙏
    thanks in advice
  • proxneo
    iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
    by proxneo
    Dear reader
    TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
    I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
    12-01-2023, 04:14 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • ipatch
    troubleshooting microsoft surface pro 4 no power no led charge light
    by ipatch
    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
    10-05-2023, 11:59 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
