HP G62 NB reballing and undervolting
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    As promsed, here it is. This isn't the first laptop this guy brings in for me to fix, and he told me he bought it for his dad, so i tried my best to do a good job.
    Apparently it had been reflowed before, but other than the epoxy being removed from the corners of the NB, i saw no other signs. And the bad solder balls were visible to the naked eye on the edges. So i think whoever attempted to reflow it used a hair drier or something... Still, better than using a heat gun and frying the board beyond repair.
    Reballing went smooth with no problems, as usual for these RS880M chips. I haven't encountered problems with them yet, it's the boards that can be a pain in the rear sometimes. This one was okay.
    Notice the crap brownish paste in the first pic. Don't know what that stuff was, but i cleaned that stuff off put MX-4 on it before putting it back together I also found a shim on the NB, cut to size rather nicely. I called him to ask, and he said it wasn't there, he did it. I thought it looked good so i put MX-4 on both sides and sandwiched it back in there.
    I also did some undervolting to the NB core, you can see the mod in pic 7. I could've likely gone further down, but i wanted a 100% stable mod that i won't have to tear the laptop down again to tweak it. The mod i did lowers NB core voltage by about 12%. I don't recall the exact numbers right now, i'll get back with more data once i get home.
    I'm posting from it right now, it's been running for a good few hours no problem. As for the temperatures, well, i can't tell you. Not that it's a secret, but it doesn't have a temp sensor! The back gets warm but not hot, and BatteryBar reports ~16W of power consumption when running on battery browsing the web. I think that's fairly good for what it is. It's got a 2.4GHz Turion II and 4GB DDR3 memory, and it's the model with integrated graphics.
    I'll upload the Excel spreadsheet for calculating the voltage output of the RT8208A regulator used for the NB core in a bit. Keep your eyes peeled.
    A working TV? How boring!
  • dellxps15
    • Feb 2014
    • 1590
    • italy
    Re: HP G62 NB reballing and undervolting
    good work!!! i did a g62 but was an intel version didnt think of undervolting nb because im afraid of bad stability and wont notebook come back after few days.... even if it can happen when reballing
    did u go with 0.35mm balls ? or normal 0.5 ?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Intel chipsets generally come with the right voltage from the factory. You could have undervolted GPU though.
      With those AMD RS880M so far i think the chips themselves are good. The boards have too small pads and i think that's why they break.
      Why would i go for smaller balls? It was made for 0.5mm balls, i used 0.5mm balls. 63/37 of course.
      Spreadsheet is attached. Putting a 4k7 in parallel with the existing 2k67 in PR72 position resulted in a 1k7 equivalent resistance (they left room for it so why bother removing the original one?). This translates to a decrease from 1.1v on the high step to 0.97v, and from 0.95v on the low step to 0.88v. This may not sound like much, but a quick calculation reveals it decreased the power consumption of the NB by roughly 2W, which is still significant. A cooler machine with longer battery runtime is always welcome.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        you got it so hot the solder came up on the blank places. You should try to ball some GDDR chips in those places
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Nah, the solder was there from the factory. I got it as hot as it needed to be, no more, no less.
          This is the onboard graphics model, but there IS a place next to the NB for a chip of DDR2 or DDR3 (can't be arsed to look up the datasheet now), acting as "sideport memory" for the IGP. I could have fitted that in, but it wasn't my laptop. I've already given it back yesterday.
          Little bit of a bonus tho, i might be hooking up with this guy's sister. He was out of town so he gave the laptop to her, and it's her again who picked it up. When i received it i was late and she was tired from work, so i didn't want to try anything as she was probably mad at me for being late, but i thought she was kinda cute and left a mental note to try and get a date when we meet to give her the laptop back.
          This time i arrived on time and thought "what the hell" and went out of my way to hang around with her a bit. Then i asked if i can keep her number and call her so we can go out again sometime, and she said yes.
          I love my job.
          • Stanley1843
            BEST 505 Vs Mechanic Brand Reballing Balls with Lead
            by Stanley1843
            has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
            06-22-2024, 11:06 AM
            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-12-2024, 02:30 PM
            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
            09-06-2024, 08:10 PM
            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
