Alienware 17 R4 LA-D751P - Battery Not Charging
  • hobostove
    • May 2023
    • 73
    Was water damaged (pint of beer). I've been messing with it and it's mostly up, but there's an issue with the battery not charging.
    The original was DoA, so there's a new one in there now. On the bench psu, measuring the battery connector (battery is 15.2V), the connector shows 16V and 9A on the 19.5v psu!
    This lasts a second or two, then it settles down to 14V, 0.06A. Unplugging AC power and it shows 13.5V. Do we think battery or board (BQ, Mosfet, etc)?
    Link to schematic
  • FriedFred
    • May 2024
    • 137
    I think 9 Ampere is absolutely not normal as a charging current. Usually, it starts with a testing sequence, and a little current. After the raising voltage is detected, the current will be raised up to a nominal charging current. I would expect a pre-charge current of let's say 100mA or 200mA or so. Then, after some seconds, the charging current can go high to 2A or 3A or maybe 4A. But 9A sounds to me like a dead-short anywhere.
    But it depends on the current demand of the product. What says the spec label on the bottom of the case about the required current and voltage?
    • hobostove
      • May 2023
      • 73
      Okay, ordered another battery to rule that out.
      The battery is at 11V right now. When I add AC power, the battery connector goes up to 19V briefly, then settles down at 11.5V, but it's not taking current. Taking off AC power, and it goes back down to 11V. I replaced the BQ chip.
      I'm thinking one of the mosfets?
      Datasheet: https://www.badcaps.net/forum/showthread.php?t=74069
      • hobostove
        • May 2023
        • 73
        I found the low side mosfet PQ706 was shorted. I replaced it with one that tested good, but that one went short immediately. I tried another, and same thing, shorted. There's no short on the board. What could be killing these mosfets?
        • mon2
          • 14152
          Which mosfet part number is being used for the replacement?
          • hobostove
            • May 2023
            • 73
            I used AON7380. I ended up finding the first DC-in mosfets were short. Once I replaced those the low charging mosfet survived. It's charging now.
            • mon2
              • 14152
              Excellent!
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Simone Vergani
                Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                by Simone Vergani
                I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                To assist with troubleshooting, I'm attaching two power circuit schematics:
                • Power
                03-05-2025, 02:25 PM
              • kodox
                ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                by kodox
                since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                what i've done:
                - flashing...
                12-29-2024, 02:49 AM
              • Shinju
                Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                by Shinju
                Hey All!
                Long time forum member here with a problematic laptop issue!
                I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                The laptop would not power on with the new battery installed without the power supply being plugged in.
                When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                10-20-2021, 04:58 PM
              • Iherduleikgemz
                Asus FX505DY - Battery not charging - BQ24780S
                by Iherduleikgemz
                Hello everyone
                I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                01-13-2025, 03:54 PM
