Lenovo E15 Gen 1
  • dancu.alexandru@gmail.com
    • Jun 2024
    • 19
    Lenovo E15 Gen 1
    I have a weird problem with a Lenovo E15 Gen 1, intel i7 processor.
    The battery is charging fine with 2,2 Amp but the board is not coming on.
    Main power rail with battery plugged in is 12,5V and without battery 9,2V.
    3,3V LDO, 3V and 5V power rails are present, current draw without the battery is 0.039 Amp and when i press the power button iti goes to 0,041 Amp and then drops back to 0.039 Amp and the power button led comes on and stays on.
    I`ve tried to change the bios with one found on this forum but no changes.
    Could someone please help me with this problem? What schoud i check?
    Thank you
  • tomodachi
    • Apr 2012
    • 614
    • Turkey
    RTC reset ?
      • Jun 2024
      • 19
      Originally posted by tomodachi
      RTC reset ?
      Yes, i also flashed BIOS but nothing changed.
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • mrkmpn
        Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
        by mrkmpn
        Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
        This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
        03-13-2024, 01:54 PM
      • pabloroggeri
        Lenovo V310-15ISK - It doesn't work after changing the battery
        by pabloroggeri
        Good guys. I changed the battery to a Lenovo V310-15ISK.
        The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
        When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
        08-23-2024, 12:01 PM
