Acer Aspire 5252 missing network(lan) in device manager
  • Scootie
    • Feb 2014
    • 133
    • Romania
    I got this laptop cheap from someone because the laptop didnt start up. The fix was easy, I had to reball the gpu. So far so good. After I installed a new windows I noticed that Im missing the network(lan) from device manager, no matter how many times I hit refresh it wont show up. Wifi is okay.
    Curios, both leds light up when I plug cable into the port.
    Motherboard model is:
    HannStar J
    MV-4
    94V-0
    or PEW96 LA-6552P.
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Acer Aspire 5252 missing network(lan) in device manager
    try this schema
    • Scootie
      • Feb 2014
      • 133
      • Romania
      Yes, thank you but already found the schematic. Lan circuits are on pg 24-25 and im trying to figure out how to interpret them. Truth to tell, it's the first time I dwell really into schematic reading.
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        try plug a cable on laptop and see if lan comes in
        • Scootie
          • Feb 2014
          • 133
          • Romania
          Nothing happens.
          I managed to read and check all voltages from p.24. They all check, tough instead of 3V i have 3.3V but I dont think that matters.
          However I noticed that there is a slight discolour on the lan chip(lower right corner) as shown in the picture, which I could'nt clean away. I check the voltages around and some pins had 1.2V, 3.3V, less then 1V or nothing on them. Im not sure that counts for something.
          • dspok
            • Jan 2014
            • 553
            • Nepal
            @Scootie
            Did you check LAN config if it is enabled in BIOS?
            • Scootie
              • Feb 2014
              • 133
              • Romania
              Yes, it is enabled, the bios was also reset(baterry out).
              • dspok
                • Jan 2014
                • 553
                • Nepal
                @Scootie
                I would like you run Linux Live CD & see if LAN works (to be sure).
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  try with linux. did the computer got hit by a flash (the one when there is bad wheater)
                  • Scootie
                    • Feb 2014
                    • 133
                    • Romania
                    Hmm, bad news. Original problem has returned. Laptop starts but no video signal on screen or external vga is present. At one point from some reason it started, I got into bios to check again network status but the only option for t is a network boot rom which I enabled but still no presence of it in device manager while in windows, the green(only) light still lights up while cable is inserted.
                    Meanwhile, im downloading a livecd of knopix.
                    The gpu is a 216-0752001. Anyone knows if these have problems? I will try to reball it monday when I return to work.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      That NB/IGP is questionable indeed. However, i've done many of them and they all have one thing in common - very small pads on the mainboard. Maybe you didn't clean it thoroughly and some dirt or oxide was left on some of them, causing an intermittent connection.
                      The LAN is connected to the southbridge however - i suspect that board may have other issues as well. Has the laptop been dropped?
                      A working TV? How boring!
                      • Scootie
                        • Feb 2014
                        • 133
                        • Romania
                        That could be, Ill be back next Monday.
                        • Chieftain
                          • May 2016
                          • 72
                          • Greece
                          Network problem is unfortunently from KB926QF... reprogramme (if you have programmer for this) or replace it.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            KB926QF is not programmable my friend.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3582
                              • slovakia
                              did u check enabling options in bios?
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                The last post from the OP was 6 years old.
                                  ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-12-2024, 03:28 PM
                                  ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-12-2024, 02:30 PM
                                  ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                  This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
