Samsung NP300E4
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Samsung NP300E4
    Laptop is running good but USB, Sound & couple of other devices are not detected in said laptop.
    Last time I fixed USB/Camera issue on Toshiba laptop in which some caps near ICH were missing.
    Is it problem with ICH, any ideas?
  • dj_ricoh
    • 2073
    • uk
    Re: Samsung NP300E4
    you need to be 100% sure with usb and sound
    like with usb you need to test powered usb like usb hdds with power adapters.
    how many os did you try? did you do a bios update?
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Re: Samsung NP300E4
      thanks @dj_ricoh
      I tried on minixp, linux, & windows 7 and even on BIOS usb is not detcted.
      5V is present on usb btw.
      • dj_ricoh
        • 2073
        • uk
        Re: Samsung NP300E4
        do you know the symptom on a hp dv series?
        dvd goes off wifi goes off sound goes off because it needs reball or a new chipset.
        try a soft reflow and see.
        • dspok
          • Jan 2014
          • 553
          • Nepal
          Re: Samsung NP300E4
          @dj_ricoh
          I didn't knew about hp dv series becoz no such issue came to me yet.
          I will try a soft reflow. Thanks for a clue btw.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            Re: Samsung NP300E4
            Thi things have on work the southbridge. So try reflow it first.
              09-07-2024, 05:50 AM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • dqtech
              Lenovo Yoga 12 LA-A342P usb not detected but does charging devices
              by dqtech
              this laptop has been done by other tech...he did replace new usb port but problem still persist and early problem is both usb port not detected thumbdrive but it does charging device/phone...i need help to diagnos this problem
              here the link for schematic - https://www.badcaps.net/forum/troubl...42p-schematics...
              03-15-2025, 09:59 AM
              09-06-2024, 11:40 PM
