Lenovo Ideadpad gaming 3 15ACH6 not powering on
This topic has been answered.
  • questore
    • Dec 2015
    • 488
    • csongrád
    Hi Everyone.
    Board number is: LA-L171P Rev: 1A
    This laptop came to me as faulty.
    After some measurments I have noticed that 3.3V line has 5ohms resistance. After injection, EC was lit up like a christmas tree.
    EC removed, Short is gone, and every other line shown normal resistances so I have ordered a new pre-programmed EC
    EC come and I have soldered it. (Checked pins 4 times for shorts and connections to pad)
    Now when AC plugged in, The following lines come up normal:
    + VCIN1_AC_IN = 3.3V
    +3VLP = 3.3V
    + EC_ON = 3.1V
    + 5VALW = 5.1V
    + 3VALW = 3.3V
    + 3V/5VALW_PG = 3.2v
    + 1.8VALW = 1.8V
    + 0.8VALW = 0.75V
    + ON/OFF# (3.3v and goes to 0V for a moment when power button pressed, checked on the EC pin also)
    My Problem is that EC_RSMRST# signal stay 0V never rises. (pin nr 100#)
    Resistance is 100 ohms after AC plugged in (at NO power state the resistance is 32Kohm)
    What could be a problem?
    Thanks for any help!
  • Answer selected by questore at 06-29-2025, 09:29 PM.
    questore
    • Dec 2015
    • 488
    • csongrád
    After ordering a connector and reading the EC it turned out that the problem was indeed the firmware. I dont know what it was programmed for and why the seller has to lie about it.
    After reprogramming the laptop turned on and works. Thanks for the help.
    • questore
      • Dec 2015
      • 488
      • csongrád
      Flashed BIOS 3 different bin from here and one from manufacturers site...no change,
      • mon2
        • Dec 2019
        • 14029
        Review the clock on the EC. The EC is a stand alone microcontroller (8051 / Arm / Cortex) that needs a clock to operate.
        • questore
          • Dec 2015
          • 488
          • csongrád
          Can you guide me how to do that?
          • mon2
            • Dec 2019
            • 14029
            Check the voltage to ground of pin #37 of the EC. This is signal name EC_RST#. This signal should be a logic '1' else the EC is parked in the reset state.
            • questore
              • Dec 2015
              • 488
              • csongrád
              EC_RST is 3.2V (High)
              • mon2
                • Dec 2019
                • 14029
                Good.
                Review this boot sequence. Where does your board fail?
                • questore
                  • Dec 2015
                  • 488
                  • csongrád
                  Good.
                  EC_RSMRST never goes high. stays at 0.005v
                  ON/OF is 3v and when power button pressed goes to 0v for a sec then back to 3v
                  • mon2
                    • Dec 2019
                    • 14029
                    Not at my desk but check if there is a local pull up resistor on this line. This output signal may be an open drain type and for this reason, the external pull up resistor is mandatory.
                    • questore
                      • Dec 2015
                      • 488
                      • csongrád
                      RC36 should be that its a 22Kohm resistor but it is not on the direct line of the EC, and no boardview so how do i find it other than continuity check on every 0402 resistor?
                      • mon2
                        • Dec 2019
                        • 14029
                        Remove all power. Measure the resistance from this signal to +1.8VALW. What is the resistance?
                        • questore
                          • Dec 2015
                          • 488
                          • csongrád
                          You are right 22k resistance it is
                          • mon2
                            • Dec 2019
                            • 14029
                            So the mystery pull up is onboard and of the correct value.
                            What is the resistance to ground of this signal?
                            • questore
                              • Dec 2015
                              • 488
                              • csongrád
                              when connected to AC adapter it is 32 ohms
                              • mon2
                                • Dec 2019
                                • 14029
                                You should never measure resistance or diode mode with power to the device under test.
                                Remove all power and measure the resistance again.
                                • questore
                                  • Dec 2015
                                  • 488
                                  • csongrád
                                  Understood, thank you. with no power the EC_RSMRST resistance to ground is 32 kohms
                                  • mon2
                                    • Dec 2019
                                    • 14029
                                    So this output signal is not shorted but is also not a logic '1'. Parked in the active low state so keeping the external logic in reset state.
                                    Curious on the voltage to ground measurements of the following (with the power adapter):
                                    EC_SMB_CK1
                                    EC_SMB_DA1
                                    EC_SMB_CK2
                                    EC_SMB_DA2
                                    Each should be ~3 volts.
                                    What is the voltage to ground of ADP_ID? This analog voltage defines the power rating of the power adapter. If this voltage is not matching the schematic values, then the adapter will be considered to be not suitable to power the board.
                                    Is the vendor for this pre-flashed EC reliable?
                                    • questore
                                      • Dec 2015
                                      • 488
                                      • csongrád
                                      EC_SMB_CK1
                                      EC_SMB_DA1
                                      EC_SMB_CK2
                                      EC_SMB_DA2
                                      Click image for larger version  Name:	PS_ID.png Views:	0 Size:	18.2 KB ID:	3587461
                                      EC_SMB_CK1 = 3.2V
                                      EC_SMB_DA1= 3.2V
                                      EC_SMB_CK2 = 0V
                                      EC_SMB_DA2= 0V
                                      ADP_ID = 1.8V (135W charger correct)​
                                      • questore
                                        • Dec 2015
                                        • 488
                                        • csongrád
                                        Originally posted by questore
                                        EC_SMB_CK1 = 3.2V
                                        EC_SMB_DA1= 3.2V
                                        EC_SMB_CK2 = 0V
                                        EC_SMB_DA2= 0V
                                        Correct me but EC_SMB_CK2 and DA2 should rise after 3VS so they are irrevelant now.
                                        New symptom...
                                        After cleaning every IC I have seen visually corroded with isopropil alcohol 99%, then the EC_RSMRST risen up for 1.7V for 2 second, then went to 0v.
                                        Now UT3 is shorted so I have removed It, but is should not matter i guess cause EN1 and EN2 are not present yet.
                                        Thermal camera shows 3 IC getting warm around normal temp 23 degrees PUV1 UL1 and EC
                                        RTC_CLK also not rising could the problem be that one of the crystal is not oscillating?
                                        • questore
                                          • Dec 2015
                                          • 488
                                          • csongrád
                                          32.768 khz is OK
                                          I'm not sure but is it possible that maybe RSMRST is there for a spilt second then it goes to 0v?
                                          (Cause when plug in the charger the multimeter is rising for a second but so fastly goes to 0v that maybe i cannot catch it.)
                                            Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ACH6 boardview and Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:30 AM
                                            Lenovo IdeaPad Gaming 3 Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad Gaming 3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 boardview and Gaming 3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 07:20 AM
                                            09-07-2024, 07:19 AM
