Looking for chip identification
This topic has been answered.
  • GadgetsFix
    • Feb 2021
    • 7
    Hi guys,
    I am looking for some help identifying a chip.
    I have a
    MateBook X Pro MACH-W29 SP1MACHW19M VER B. I need to replace the chip in the photo. The identifying marks read: 7534 GA8T1T.
    Thank you for any help!
  • Answer selected by GadgetsFix at 03-07-2025, 06:09 AM.
    atmega4
    • Jun 2017
    • 36
    • oran
    AON7534 Low Voltage MOSFETs (12V - 30V) Status: Full Production 30V N-Channel MOSFET 20A (Ta), 30A (Tc) 3W (Ta)
    • noname2024
      • Aug 2024
      • 288
      • CỎ MỸ XỊN
      This N-mostfet
      • atmega4
        • Jun 2017
        • 36
        • oran
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • Loki_Fido
          Requesting help identifying chip in Macbook Pro A2485
          by Loki_Fido
          Hi ya folks,
          I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
          It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
          I replaced it and the SSD are fine. No more shorts.
          But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
          But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
          Chip marking...
          08-07-2025, 10:17 PM
        • e-repair
          Chip identification on hp omen 17cb1008tx
          by e-repair
          Hello !
          i have an to repair an hp omen 17cb1008tx.
          i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
          can you help me find a reference for this ic ?...
          09-23-2025, 03:38 AM
        • skdsp
          Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
          by skdsp
          I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
          Attached is the photo.
          Thank you!
          09-27-2025, 09:05 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
