Macbook air a2337 wifi/Bt chip short
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    Macbook air a2337 part no 820-02016 wifi/bt chip is burned mark can I replace this chip will work I have same donor board
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • Guest
    A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
    by Guest
    Hello all!
    Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
    After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
    09-26-2024, 03:31 AM
  • Loki_Fido
    Requesting help identifying chip in Macbook Pro A2485
    by Loki_Fido
    Hi ya folks,
    I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
    It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
    I replaced it and the SSD are fine. No more shorts.
    But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
    But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
    Chip marking...
    08-07-2025, 10:17 PM
  • duwane
    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
    by duwane
    Hi All.
    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
    10-17-2023, 07:48 PM
  • corrize
    Asus Zenbook UX433F UX433FA wifi up and down and chip hot
    by corrize
    Hello, on this laptop, the wifi can be up and stop working. I noticed it never works without battery, except long time after I remove the DC jack, and it stop to works (Bluetooth too). It diseapper to window and still 2 exclamation points in the device list.
    The wifi chip is hot when the laptop is on.
    I made a bios update but the same.
    That could be a thermal issue, I measured 2 caps shorted (0 Ohms) beside the chip (+3V_WLAN according the bordview), but not since (so I have doubt what I saw). After, I measured 50 Ohms when battery plugged and K Ohms...
    05-15-2023, 04:05 PM
