I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show orange & white light from the left side and shut off after the battery would drain itself due to an assumed short on the motherboard.
I opened the laptop thinking I could do some practical diagnosis, I only see that the 19V of power comes through the DC jack and the closest mosfet is seeing 19 V on the top side while the main power rail sees a voltage range from 2.15 to 2.22V.
I've taken out the motherboard and have typed my discoveries on the images for the front side and back side of motherboard. Both sides of the motherboards have 1 faulty capacitor. I'm curios if the 2 bad capacitors discovered could lead to the symptoms that I'm seeing. The bad cap on the front side is close to the inductor that has continuity, that's close to the CPU. I'm tempted to remove the cracked capacitor from the front to see if the continuity from the inductor will disappear, any thoughts?
