Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
  • bk304
    • Jan 2025
    • 22
    I gave up. I determined that the short is in the 5V circuit. I removed the PD chip and the 5V regulator. I injected 5V and cranked up the current and nothing much happened. I found one part of a trace on the circuit board that showed up on the thermal image. I could not find any other component that stood out. Usually it's a cap, a diode, or a MOSFET. That would be easy to fix. I don't want to put anymore time into this one. I made a copy of the BIOS if someone needs it.
    • mon2
      • Dec 2019
      • 14995
      5v short may be the vbus rail or load switch used by the usb ports.
      • facta
        • Aug 2018
        • 15
        • malawi
        hello GUYS, i would like to ask about TPS65994AD/AE PD controller recently it is becoming a common problem on Type-c connectors. does this require programming before installation or if yes how do we program it. i have several of these new chips from different suppliers but none worked on several models of laptop where they will turn on from a charged battery but fail to power from charger or negotiate 20v . please help.
        • mon2
          • Dec 2019
          • 14995
          After a bit of reading of the PD controller by Texas Instruments, the TPS65994AD/AE PD controller can be configured by an external EC over I2C OR an external EEprom.
          In reviewing the Lenovo LA-L931P laptop schematic, this PD controller is being configured by an external EEprom. See attached.
          Be sure that U15 is properly soldered and is present on your board. From my understanding, U15 is holding the configuration firmware for this PD controller. If all looks well for this controller then perhaps the contents of this standard eeprom is corrupt.
          • facta
            • Aug 2018
            • 15
            • malawi
            well explained and now it is making sense to me using the example provided.
            i can confirm that i have u15 properly soldered and am yet to check the status but i believe it is okay and i have downloaded TI customization tool just to get familiar with the interface as shown below.
            my next question is which programmer do i use to program this eeprom via I2C bus? i only have CH341A Mini Programmer for the bios and would like to know if this is compatible? lastly is the Dump inside the eeprom useful in anyway during the process of build the configuration file?
            the attached schematic is for DELL latitude 5530 and i once failed to fix it with same problem and i want confirm what is written on your TPS65994AD datasheet that sometimes configuration file is stored in an external EC as shown below.
            • mon2
              • Dec 2019
              • 14995
              Yes, the 24c256 eeprom should be supported. Only perform a read and save copies of the original to archive the current firmware. Ideally, for testing, you will need a full dump of this eeprom from a known good and working motherboard. Also post this pd eeprom dump in the bios section forum.
              • mon2
                • Dec 2019
                • 14995
                On the Dell, the firmware is injected over the i2c lines driven by the EC. Check the bios local to the EC or attempt a full bios reflash of the main bios. This process may apply the current pd firmware. Post all updates.
                • facta
                  • Aug 2018
                  • 15
                  • malawi
                  #28
                  i checked u 15 and it is okay because i have found 3.3v on I2C pins(5,6) as well as pin 8 and i have copied and pasted the dump on BIOS FORUM
                  so you believe copying the eeprom file from a working laptop will solve my problem? what kind of laptop; same brand or model or any other laptop which has same configuration?
                  For the dell laptop i returned it to the customer because i gave up after failing three times up until this lenovo came.
                  however i want to testify that TPS65994AD/AE has two form factor : QFN (48) and BGA (50 pins), the QFN model doesn't require programming because i have replaced them over 10 times in models like lenovo thinkpad t16, T14 gen 3 and i never experience the problem that am having with BGA version and now am interested to learn by understanding this configuration and i appreciate your effort to help me.
                  • ricardoporto1
                    • Dec 2025
                    Hi Mom2, I was having issues with my ipad charging, but I am a eletronic student and I finished damaging a component that I have no idea the value of it to be able to replace it. Please, would you hve the i Pad 5 Schematic with part names to share. Thank you for your help.
                    • mon2
                      • Dec 2019
                      • 14995
                      Umm..which part? Post a few pics of the region of the board and identify the missing part location. The schematics should be available in the schematic forum but can check my database.
                      • nikolayu
                        Dell Latitude 5420 wont turn on when charger is connected
                        by nikolayu
                        I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                        Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                        The same thing if I connect to other USB C port.
                        Charger is OEM
                        03-13-2024, 12:34 PM
                      • motormayhem
                        Lenovo T460 Only Charges on One Charger
                        by motormayhem
                        Laptop Question
                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                        05-12-2023, 01:46 PM
                        DELL Inspiron 5420 Notebook 5000 Specification for Upgrade or Repair
                        This specification for the DELL Inspiron 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5420...
                        09-07-2024, 06:38 AM
                      • u666sa
                        HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                        by u666sa
                        Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                        Platform: ipa32 la-m024p rev 1b
                        Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                        I found a short on the other side:
                        10-04-2025, 05:03 PM
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
