Dell Latitude 5420 P137G
Board: LA-K491P REV A01
I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
Board seems to have no shorts, all power rails are fine and show high resistance.
When charger is plugged in, voltage is present in 3.3V rail but absent in others. Testing for 20 volts at +20V_LDO_INPUT and +20V_TBTB_VBUS shows between 4.5-5 volts instead. Does this mean the system is failing to negotiate with the USB-C to go from 5 to 20 volts? And if so, what would be my next steps in the diagnostic process? I am using a brand new OEM Dell 65w charger so it shouldn't be a problem with the cable.
