KBC EQUIVALENT
  • mo000
    • Nov 2017
    • 276
    • algeria
    KBC EQUIVALENT
    HI EVERYONE
    is the IT8689E BXA EQUIVALENT OF IT8689E CXA can i replace IT8689E CXA WITH ANY IT8689E ,
    someone replaced IT8689E CXA WITH IT8686E CXA he mentioned after replacement don't found in bios cpu temp and fan speed but the motherboard works fine .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    The suffix is important. In some cases replacing a BXA with CXA or vice versa works and in some cases it wont work. So best is to source the exact suffix chip(specially if the mb is asus)
    • mo000
      • Nov 2017
      • 276
      • algeria
      motherboard is gigabyte b550 but i can't fine IT8689CXA SO I GO WITH IT8686E CXA
      • BoBtimus
        • Oct 2024
        • 11
        • Deutschland
        so how did it work out? facing the exact same problem right now...
        • mo000
          • Nov 2017
          • 276
          • algeria
          i use IT8686E CXA and motherboard works fine
          • vatecnica
            • May 2021
            • 41
            • Argentina
            did anyone know the diference with the it8686e- DXA, CXA and DXS because i haave a b450 aorus elite v2 with DXA and i can buy the CXA or DXS,, i guess if i bought the CXA could work but didnt know the diference anyoney know about this? thanks a lot!!
            UPDATE: i just resolder the rtc IC and it works!
            https://www.badcaps.net/forum/troubl...s-not-power-on
            post 12 said this!
            • nix30101
              Thoughts on Reverse Engineering 8FC8 suffix logic..
              by nix30101
              Greetings i am in the process of reverse engineering the bios logic for the 8FC8 suffix so far I have found most of the bios functions related to the suffix from a bios dump and I have verified inputs and outputs to test with plus the chartable for the 8FC8 suffix.
              12-16-2024, 12:50 PM
            • tmcw
              Drying Oven - Preset Temp Fail
              by tmcw
              Here's an unusual one...
              This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
              It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
              However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
              01-21-2021, 03:11 AM
            • foshland
              MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
              by foshland
              Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
              Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
              External temperature (motherboard temp) is working OK, 27ºC more or less
              In windows, all the software I have tested shows correct the Core temps
              12-16-2023, 09:08 PM
            • mosfetratus
              concerning gtx675m vram temp
              by mosfetratus
              Is 98C vram temp are safe? Less demanding games goes 80ish.
              Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
              furmark goes about 104C, amperage keeps rising so do temps.
              01-30-2025, 08:41 AM
              Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
              The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
              Securing a good thermal interface between...
              10-07-2024, 04:35 AM
