Thatkind of laptop and it has very faint image on bios almost nothing with the flashlight..i allready change the screen(led) and still no joy..could it be the famous nvidia/ati gpu?and i did proper reflow with goodknown flux but still the same.
HP DV2-1130 dim pix
by wnt2fxI have an 2016 12" MacBook here which does not recognise the ssd most of the boots and if does once upon a time it usually does not complete the boot.
I wanted to benefit from your experience:
It is 2016 and not the longish 2015 CPU. I can not clearly see that is warped.
Would you check anything else before attempting a reball / replace of the cpu ?
And, as a less important side question: Could I install an m7 on a board that came with m3 ?
best regards -
Gigabyte z490 aorus pro ax Mothterboard have 3 pcie slots . when i plug vga card debug led stuck in VGA LED ... my vga card is good .... i think fault have in my motherboard pcie express slots ....moterboard onboard vga is display ok ...
i allready clean all pcie slots 12V ok 3.3V Ok .....
anyone can help to repair this problem .... thank you... -
by TimSingerHi guys,
I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
I attached a photo of the missing cap. It's on the bottom side of the logicbard.
I am very thankful for your replys.
Thanks in advanced and best regards from Hamburg Germany...07-13-2025, 11:12 AM -
Gigabyte h310m s2h rev 1.1 motherboard come bios screen and keep restarting .sometime 2 3 times fan spring and off after come bios screen . some time working 15 to 30 minutes .
I allready checked
VCCPLL voltage ok
VCCIO Voltage ok
VCCIO Enable ok
VCCSA Voltage Ok
VCCSA Enable Ok
VRM IC voltages ok
Replaced VRM IC
Replaced LM358 ic
Re programed Bios
But sometime motherboard working 20 30 minutes and restarting ......sometime have fan spring and off error ..........anyone have solution...07-08-2025, 10:16 AM -
by sassanhello,
i want to buy a new programmer mainly for use for laptops bios chips and i'm between the Xgecu T76 and the famous RT809H.
i think that T76 is faster wich makes it the best choice for using Pogo pins,i asked the support if it supports Mec ships found on some Lenovo laptops i didn't get an answer yet.
i would like some ideas and which one do you recommend?... - Loading...
